[Gdal-dev] No support for widestrings in ArcSDE driver for OGR ?
Howard Butler
hobu.inc at gmail.com
Tue Mar 10 09:54:33 EDT 2009
Is there a ticket for this issue? If not, could you please file one
and attach the patch to it?
Howard
On Mar 10, 2009, at 8:49 AM, Anders Moe wrote:
> Hi
> I'd be happy to test this out for for ArcSDE 9.2 (9.3 a bit later).
> I've
> just pulled the latest stable and saw no change to the ArcSDE driver
> related
> to widestrings I applied my own private patch as a workaround
> (attached).
> Regards,
> Anders.
>> I would fix it myself and submit a patch, but ironically enough, I
>> don't
>> have a way to test it or compile it since I don't have ArcSDE nor
>> ArcGIS
>> anywhere... should I submit a ticket?
> Ragi,
> I'm in the same position - no SDE instance to test against. A patch
> might
> be good if either Howard or Anders are willing to commit to testing
> it out.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for
> Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> http://n2.nabble.com/file/n2455262/d.txt d.txt
> View this message in context: http://n2.nabble.com/No-support-for-widestrings-in-ArcSDE-driver-for-OGR---tp2036034p2455262.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
