[gdal-dev] gdal contour, output polygon
ValiSystem vali.system at free.fr
Thu Mar 12 13:46:18 EDT 2009
that's a very interesting option ! I think i could write a tool in C++
to do the grouping, and use the original line strings for the elevation
lines/text.
thanks a lot
On 12/03/09 17:26, Jamie Adams wrote:
> You could also try using gdal_polygonize
> <http://www.gdal.org/gdal_polygonize.html>, but you'd need to find a
> way to reclass your source raster to discrete groups (i.e, elevation
> ranges).  This could be done pretty easily using python, maybe
> something like val_repl.py
> <https://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/val_repl.py>.
> -Jamie
> On Wed, Mar 11, 2009 at 12:56 PM, ValiSystem <vali.system at free.fr
> <mailto:vali.system at free.fr>> wrote:
>     Hello !
>     I'm trying to generate polygons from gdal contour output. Most of
>     the linestrings generated where closed, so it's not a too bad
>     start. The problem is to define interior and exterior of the
>     polygon : it seems that interior and exterior has no consistent
>     meaning from the linestrings (it makes sense though - a line has
>     no interior nor than exterior).
>     So what i need would be a method to recreate the meaning of the
>     polygon : the inside is where i have ground. To make it work, i
>     just would have to transform the polygon to an interior ring of a
>     wider (whole area) polygon when appropriate (when it does not
>     contain a polygon with a higher altitude).
>     What do you think about this ? is there a better/known way to
>     achieve that ?
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090312/ff153a9b/attachment.html
