[gdal-dev] ogr2ogr on SDTS/DLG creates wrong geometries
Frank Warmerdam
warmerdam at pobox.com
Thu Mar 12 21:23:59 EDT 2009
Bill Zissimopoulos wrote:
> Hello, list:
> I am using ogr2ogr to convert SDTS/DLG files to SHP for further
> processing. The command I use is as follows:
> wget http://edcftp.cr.usgs.gov/pub/data/DLG/100K/S/seattle-w_WA/hydrography/1431327.HY.sdts.tar.gz
> tar xzf 1431327.HY.sdts.tar.gz
> ogr2ogr -f "ESRI Shapefile" -t_srs EPSG:4326 . *CATD.DDF
> This downloads the hydrography for the area west of Seattle, extracts it
> and runs ogr2ogr to convert to Shapefile format.
> Unfortunately some of the produced area geometries appear to be
> problematic. For example, the result file PC04.shp contains some weird
> "empty" geometries: these seem to be comprised of a big "fill" polygon
> and a number of "hole" polygons such that their difference is an empty
> geometry. The most obvious such example is the "sea" area behind
> Bainbridge island (ENTITY_LAB 0500116).
> I have verified that the original SDTS/DLG file renders properly under
> software capable of reading such files (e.g. GlobalMapper). Is this a
> problem with ogr2ogr or am I misusing/misunderstanding the tools?
Bill,
I have downloaded the 1431327.HY file you referenced, but ogrinfo on
the PC04 layer does not show anything fundy about the 0500116 polygon.
I also converted to shapefile format and examined that with no odd results.
I neglected to reproject to EPSG:4326 I see.
Perhaps you could file a ticket on the issue, being very specific about
the software version and platform you worked on. Also, please check if
a direct ogrinfo report on the original SDTS file shows a similar problem.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
