[gdal-dev] ogr2ogr VPF->postgis
sophia parafina
creta.kano at gmail.com
Mon Mar 16 12:04:37 EDT 2009
slashes are incorrect, e.g.
gltp:[//<hostname>]/<driver_name>/<dataset_name>:<layer_name>:<family>
On Mon, Mar 16, 2009 at 11:38 AM, Malm Paul <paul.malm at saabgroup.com> wrote:
> Hi!
> I'm trying to read in VPF data to my postgreSQL/PostGis database with
> ogr2ogr.exe in WinXP
> The lht file is placed in c:\test\vmap\v0eur_5\vmaplv0\eurnasia
> The database is called testgis
> This is what I typed in on the command prompt:
> ogr2ogr -f PostgreSQL PG:"dbname='testgis' user='cvfc' passwd='pwd'"
> gltp:\vrf\test\vmap\v0eur_5\vmaplv0\eurnasia -lco OVERWRITE=yes -nln
> polbndl_bnd 'polbndl at bnd(*)_line'
> This is what I got:
> FAILURE:
> Unable to open datasource `gltp:\vrftest\vmap\v0eur_5\vmaplv0\eurnasia'
> with the following drivers.
> -> ESRI Shapefile
> -> MapInfo File
> -> UK .NTF
> -> SDTS
> -> TIGER
> -> S57
> -> DGN
> -> VRT
> -> REC
> -> Memory
> -> BNA
> -> CSV
> -> GML
> -> GPX
> -> KML
> -> GeoJSON
> -> GMT
> -> ODBC
> -> PGeo
> -> AVCBin
> What have I missed?
> Is it possible to load all featuretypes in a Postgis database at once?
> Kind regards,
> Paul_______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090316/7a8c3e48/attachment.html
