[gdal-dev] Re: gdal2tiles dateline gap
Roger André randre at gmail.com
Mon Mar 16 17:16:01 EDT 2009
Hi Jeff,
Adding list, just in case there is additional input on this.
Yes, but the solution I found may not be applicable to your use-case.
I needed to create Google Map tiles in spherical mercator projection,
not Google Earth KML, so I was able to use TileCache with MapServer to
generate them.  I found that I had more flexibility using that
solution, than I did using the gdal2tiles tool.
I should also add that when I used input data that was already in
sperical mercator projection, I was unable to get data all the way out
to the edges of their defined extents.  You might try converting the
input data to EPSG:4326 first, then see what you get out of
gdal2tiles.  I believe it can handle the reprojection for you
on-the-fly.
Roger
On Sun, Mar 15, 2009 at 4:41 PM, Jeff Logan <jlogan at customweather.com> wrote:
> Hi Roger,
> Gdal2tiles output  is chopping off New Zealand from a global data set...the
> input spherical mercator global image has New Zealand intact. Did you
> discover a solution after posting to 'gdal.dev' nine weeks ago?
> Thanks, Jeff
