[Gdal-dev] C# fix for supporting the libtool builds
turtlewax
fevans at harris.com
Tue Mar 24 11:01:48 EDT 2009
Tamas:
I've been working on the Mono bindings for gdal for months now. All these steps look like they might solve my problem, but I'm having trouble translating them into actions. For example:
2. $(LD) should be used instead of $(LD_SHARED) when linking the
shared libraries with libtool.
Do I define this in the swig/csharp/GNUMakefile, or with a ./configure command, or with an environment variable?
3. Should use $(SO_EXT) as the shared object extension (in every case)
Ditto for SO_EXT. Where do I define these?
View this message in context: http://n2.nabble.com/C--fix-for-supporting-the-libtool-builds-tp2029188p2527093.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
