[Gdal-dev] C# fix for supporting the libtool builds
Tamas Szekeres szekerest at gmail.com
Tue Mar 24 16:36:17 EDT 2009
2009/3/24 turtlewax <fevans at harris.com>
> 1. Should rely on $(CXX) $(CC) and including GDALmake.opt for building
> the .cpp .c .cxx files
> What does this mean, in terms of actually creating a build? In other words,
> what does "Should rely on" mean? Do I set a flag, an environment variable?
These are just technical comments/guidelines to follow when adding support
to the libtool builds in the gdal makefiles. The actual values of $(CXX)
$(CC) may vary depending on whether libtool is configured or not. But the C#
makefile have already been fixed in this regard, so you should not take much
care of these comments.
Tamas
> http://n2.nabble.com/C--fix-for-supporting-the-libtool-builds-tp2029188p2528235.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090324/dd1ba8b1/attachment.html
