[gdal-dev] Re: prj to proj.4
Hermann Peifer
peifer at gmx.eu
Wed Mar 25 13:31:07 EDT 2009
Howard Butler wrote:
> Looking at the .prj file and searching http://spatialreference.org might
> also be productive.
> Another option is to upload it to spatialreference.org, and you can then
> get it in a number of formats. This approach isn't recommended for a
> lot of SRS's, but for a quick one-off sort of thing, it's pretty handy.
> Howard
Thanks for the hint, but I have 1000's of shapefiles which have all
kinds of SRS's. So spatialreference.org doesn't seem to be the best
option in my case. Rob's python script below actually looks like what I
was looking for. Python is available on my system. I am however not root
there. I still have to convince the system admin to install the gdal
site-package, so that I can: import osr
Hermann
> On Mar 25, 2009, at 5:49 AM, Robert Coup wrote:
>> Hi Hermann,
>> On Wed, Mar 25, 2009 at 9:06 PM, Hermann Peifer <peifer at gmx.eu> wrote:
>> I am looking for a convenient way to convert the SRS parameters from a
>> random shapefile.prj into proj.4 format. A command line interface
>> would be most helpful for a non-programmer, like me.
>> If you have python on your system (likely), then you can create a
>> python script (eg. prj2proj.py) with the following code in it, then
>> run "python prj2proj.py my.prj" and it'll print the proj4 equivalent
>> of the my.prj file.
>> HTH,
>> Rob :)
>> #!/usr/bin/env python
>> import osr
>> import sys
>> def main(prj_file):
>> prj_text = open(prj_file, 'r').read()
>> srs = osr.SpatialReference()
>> if srs.ImportFromWkt(prj_text):
>> raise ValueError("Error importing PRJ information from: %s" %
>> prj_file)
>> print srs.ExportToProj4()
>> if __name__=="__main__":
>> main(*sys.argv[1])
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
