[gdal-dev] again .hdf to .tif
Yann Chemin yann.chemin at gmail.com
Thu Mar 26 12:08:13 EDT 2009
Yes Vincent,
that rings a bell indeed.
Thanks,
Yann
2009/3/26 Vincent Schut <schut at sarvision.nl>:
> Yann Chemin wrote:
>> Hi there,
>> I am using this one right now on Level 2 and 3 MODIS products
>> #!/bin/bash
>> mkdir processed
>> for file in *.hdf
>> do SDS_list=$(gdalinfo $file | grep "SUBDATASET_.*_NAME.*")
>>        for subdataset in $SDS_list
>>        do echo ${subdataset#*=} > tempfile.txt
>>        out=$(sed
>> 's/\(.*\):\(.*\):"\(.*\).A\(.*\)\.\h\(.*\)\.\(.*\)\.\(.*\).hdf":\(.*\):\(.*\)/\3\_\4\_h\5\_\8\_\9\.tif/'
>> tempfile.txt)
>>        gdalwarp -of GTiff -t_srs EPSG:4326 ${subdataset#*=} processed/$out
>>        done
>> done
>> maybe of help,
>> Yann
> Note that, when you are using modis sinusoidal projected hdf products, you
> might have to use something like this to prevent a shift in the y direction
> which becomes more pronounced when further from the equator:
> gdalwarp -s_srs '+proj=sinu +R=6371007.181 +nadgrids=@null +wktext' -t_srs
> EPSG:4326 <hdf> <out.tif>
> to force gdalwarp to adjust for the custom ellipsoid that the modis
> sinusoidal projection uses. Or, at least, I had to some time ago. It might
> have been 'fixed' already.
> Regards,
> Vincent.
>> 2009/3/26 Anja Roesel <anja.roesel at zmaw.de>:
>>> sorry i forgot to mention the error message:
>>>> Segmentation fault
>>> Hi list,
>>> I am trying to convert MODIS .hdf files to .tif files (it worked with
>>> ASTER files earlier, thats why I am now really curious).
>>> i typed
>>>> gdalinfo MOD021KM.A2008134.1935.005.2009071201911.hdf
>>> result:
>>> SUBDATASET_1_NAME=HDF4_EOS:EOS_SWATH:"MOD021KM.A2008134.1935.005.2009071201911.hdf":MODIS_SWATH_Type_L1B:EV_1KM_RefSB
>>> SUBDATASET_1_DESC=[15x2030x1354] EV_1KM_RefSB (16-bit unsigned integer)
>>> SUBDATASET_2_NAME=HDF4_EOS:EOS_SWATH:"MOD021KM.A2008134.1935.005.2009071201911.hdf":MODIS_SWATH_Type_L1B:EV_1KM_RefSB_Uncert_Indexes
>>> SUBDATASET_2_DESC=
>>> then:
>>>> gdalwarp
>>>  modis.tif
>>> Have you any ideas, what is the problem?
>>> Thanks,
>>> Anja
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Yann Chemin
Mobile: +33 (06) 10 11 39 26
Home: +33 (02) 35 27 08 20,
Address: Gite de Mortagne,
16 rue de la chenaie,
76110 Bec de Mortagne,
France
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
