[gdal-dev] Re: gdal_fillnodata error
Wesley Roberts
wroberts at csir.co.za
Fri Mar 27 03:24:35 EDT 2009
Dear list,
Sometime last week I posted a question regarding errors associated with
gdal_fillnodata. Brent Fraser kindly shared with me some C++ code he had
written to approximate the workings of the python gdal_fillnodata app.
Through trial and error (and some extra help from Brent) I have finally
gotten the code to work and compile using the following command
wroberts at wroberts-desktop:/usr/local/gdal/include$ sudo g++
-I/usr/include/gdal gdal_FillNoData.cpp -L/usr/local/gdal/lib -lgdal -o
FillNoData
unfortunately once compiled I try to run it for usage info and I get the
following error
wroberts at wroberts-desktop:/usr/local/gdal/include$ ./FillNoData
./FillNoData: error while loading shared libraries: libgdal.so.1: cannot
open shared object file: No such file or directory
I am a little lost as the file libgdal.so.1 is located in
wroberts at wroberts-desktop:/usr/local/gdal/lib$ ls -l
total 64212
-rw-r--r-- 1 root root 40876082 2009-03-17 10:09 libgdal.a
-rwxr-xr-x 1 root root 1393 2009-03-17 10:09 libgdal.la
lrwxrwxrwx 1 root root 17 2009-03-17 10:09 libgdal.so ->
libgdal.so.1.13.0
lrwxrwxrwx 1 root root 17 2009-03-17 10:09 libgdal.so.1 ->
libgdal.so.1.13.0
-rwxr-xr-x 1 root root 24795259 2009-03-17 10:09 libgdal.so.1.13.0
I now see that libgdal.so.1 is infact a link to another file.
Unfortunately I have done a 'find' for libgdal.so.1 and have tried many
combinations of paths to gdal lib folders and this is the only one that
actually compiles.
I would like to use the app to fill the gaps in Landsat ETM+ data
(SLC-off).
Does anyone on the list have ideas with regards to finding a solution to
my problem? Any help would be greatly appreciated.
Kind regards,
Wesley
>>> Brent Fraser <bfraser at geoanalytic.com> 03/26/09 4:38 PM >>>
Hi Wesley,
I'm not a Linux/gcc user so I likely can't help much. There's two
steps to creating an executable:
1. The compile step. gcc needs to be able to find any "include" files
referenced in the source code. You've somewhat solved this by compiling
in the GDAL include directory. You may want to look into how specify
additional include directories on the gcc command line (a -I option?).
2. The link step. gcc needs to be able to find compiled libraries of
functions referenced in the c++ code. This is the problem you've shown
below. You need to specify the GDAL library on the gcc command line;
something like:
g++ gdal_FillNoData.cpp -L../lib -lgdal -o fill_no_data
I found http://www.network-theory.co.uk/docs/gccintro/gccintro_17.html
to be a good gcc intro. And Frank Warmerdam gave some insight in
http://n2.nabble.com/gdal_priv.h-not-found-on-ubuntu-td2035784.html
Best Regards,
Brent Fraser
Wesley Roberts wrote:
> Hi Brent,
> Many thanks for your code and apologies for not replying sooner,
things
> have been a little busy here. As you mentioned in your mail the code
may
> need some tweaking, I received some
> warning: deprecated conversion from string constant to ‘char
> errors but have managed to sort those out through trial and error. I
> also had trouble with the include files so am now compiling from
inside
> the gdal directory on usr/local/gdal/include. This is something I will
> remedy later on, for now I am receiving the following errors and given
> my inexperience using c++ I am not able to correct the code. Could you
> please help me? Error is below.
> Many thanks,
> Wesley
> gdal_FillNoData.cpp -o fill_no_data
> /tmp/ccz4jVWn.o: In function `ga_CopyBand(void*, void*, int, int)':
> gdal_FillNoData.cpp:(.text+0x14b): undefined reference to
> `GDALGetBlockSize'
> gdal_FillNoData.cpp:(.text+0x156): undefined reference to
> `GDALGetRasterDataType'
> gdal_FillNoData.cpp:(.text+0x164): undefined reference to
> `GDALGetDataTypeSize'
> gdal_FillNoData.cpp:(.text+0x241): undefined reference to
`GDALRasterIO'
> gdal_FillNoData.cpp:(.text+0x29c): undefined referen> gdal_FillNoData.cpp:(.text+0x2e0): undefined reference to
> `GDALGetGeoTransform'
> gdal_FillNoData.cpp:(.text+0x2fb): undefined reference to
> `GDALSetGeoTransform'
> gdal_FillNoData.cpp:(.text+0x306): undefined reference to
> `GDALGetProjectionRef'
> gdal_FillNoData.cpp:(.text+0x315): undefined reference to
> `GDALSetProjection'
> /tmp/ccz4jVWn.o: In function `ga_World2Image(double, double, double*,
> long*, long*)':
> gdal_FillNoData.cpp:(.text+0x38b): undefined reference to
> `GDALInvGeoTransform'
> gdal_FillNoData.cpp:(.text+0x3b2): undefined reference to
> `GDALApplyGeoTransform'
> /tmp/ccz4jVWn.o: In function `ga_Image2World(long, long, double*,
> double*, double*)':
> gdal_FillNoData.cpp:(.text+0x467): undefined reference to
> /tmp/ccz4jVWn.o: In function `app_version(_IO_FILE*)':
> gdal_FillNoData.cpp:(.text+0x4c1): undefined reference to
> `GDALVersionInfo'
> /tmp/ccz4jVWn.o: In function `main':
> gdal_FillNoData.cpp:(.text+0x66d): undefined reference to
> `GDALTermProgress'
> gdal_FillNoData.cpp:(.text+0x6c8): undefined reference to
> `GDALAllRegister'
> gdal_FillNoData.cpp:(.text+0x6e7): undefined reference to
> `GDALGeneralCmdLineProcessor'
> gdal_FillNoData.cpp:(.text+0x7bc): undefined reference to
`CSLAddString'
> gdal_FillNoData.cpp:(.text+0x7f2): undefined reference to
> `GDALDummyProgress'
> gdal_FillNoData.cpp:(.text+0x99d): undefined reference to
> `GDALDestroyDriverManager'
> gdal_FillNoData.cpp:(.text+0xa0e): undefined reference to
> gdal_FillNoData.cpp:(.text+0xa47): undefined reference to
> gdal_FillNoData.cpp:(.text+0xa6c): undefined reference to
> `GDALOpenShared'
> gdal_FillNoData.cpp:(.text+0xa84): undefined reference to
> `GDALOpenShared'
> gdal_FillNoData.cpp:(.text+0xa92): undefined reference to
> `CPLGetLastErrorMsg'
> gdal_FillNoData.cpp:(.text+0xa99): undefined reference to
> `CPLGetLastErrorNo'
> gdal_FillNoData.cpp:(.text+0xabc): undefined reference to
> gdal_FillNoData.cpp:(.text+0xad3): undefined reference to
> `GDALGetRasterXSize'
> gdal_FillNoData.cpp:(.text+0xae1): undefined reference to
> `GDALGetRasterYSize'
> gdal_FillNoData.cpp:(.text+0xb0f): undefined reference to
> `GDALGetRasterCount'
> gdal_FillNoData.cpp:(.text+0xb74): undefined reference to
> gdal_FillNoData.cpp:(.text+0xb92): undefined reference to
> `GDALGetRasterBand'
> gdal_FillNoData.cpp:(.text+0xba0): undefined reference to
> gdal_FillNoData.cpp:(.text+0xbcf): undefined reference to
> `GDALGetMaskBand'
> gdal_FillNoData.cpp:(.text+0xbe7): undefined reference to
> `GDALOpenShared'
> gdal_FillNoData.cpp:(.text+0xc03): undefined reference to
> `GDALGetRasterBand'
> gdal_FillNoData.cpp:(.text+0xc0d): undefined reference to
> `CPLGetLasgdal_FillNoData.cpp:(.text+0xc37): undefined reference to
> gdal_FillNoData.cpp:(.text+0xc66): undefined reference to
> `GDALGetDriverByName'
> gdal_FillNoData.cpp:(.text+0xc74): undefined reference to
> gdal_FillNoData.cpp:(.text+0xc7b): undefined reference to
> `CPLGetLastErrorNo'
> gdal_FillNoData.cpp:(.text+0xc9e): undefined reference to
> gdal_FillNoData.cpp:(.text+0xce0): undefined reference to `GDALCreate'
> gdal_FillNoData.cpp:(.text+0xcee): undefined reference to
> gdal_FillNoData.cpp:(.text+0xcf5): undefined reference to
> `CPLGetLastErrorNo'
> gdal_FillNoData.cpp:(.text+0xd18): undefined reference to
> gdal_FillNoData.cpp:(.text+0xd49): undefined reference to
> `GDALGetRasterBand'
> gdal_FillNoData.cpp:(.text+0xd85): undefined reference to
> `GDALGetRasterNoDataValue'
> gdal_FillNoData.cpp:(.text+0xd94): undefined reference to
> `GDALSetRasterNoDataValue'
> gdal_FillNoData.cpp:(.text+0xdd3): undefined reference to
> `GDALFillNodata'
> gdal_FillNoData.cpp:(.text+0xdde): undefined referenc> gdal_FillNoData.cpp:(.text+0xe00): undefined reference to `GDALClose'
> gdal_FillNoData.cpp:(.text+0xe1a): undefined reference to
> `GDALTermProgress'
> collect2: ld returned 1 exit status
>>>> Brent Fraser <bfraser at geoanalytic.com> 03/18/09 11:40 PM >>>
> Wesley,
> I had the same problem when dealing with DEMs over the last few
days.
> I don't know enough about python to make it work, so I coded
> gdal_fillnodata in c++ (ish). See attached file. This is barely
> debugged, so it may need some fixes to work for you.
> Brent Fraser
> GeoAnalytic Inc.
>> Dear List,
>> Yesterday I did an install of the latest svn gdal release (think it
is
> 1.7) to my local machine. I am interested in using the
> gdal_fillnodata.py application to fill some lines in my Landsat 7 ETM
> data. When I run the code
>> python gdal_fillnodata.py -md 400
/home/wroberts/wes2006/Projects/Evapotranspiration/Data/Landsat_NDVI/test.img
/home/wroberts/wes2006/Projects/Evapotranspiration/Data/Landsat_NDVI/test.fill.img
>> I get the following error
>> gdal.FillNodata() not available. You are likely using "old gen"
>> bindings or an older version of the next gen bindings.
>> I am not sure what this means, could somebody suggest a solution or
> work around. I am currently trying r.fillnulls in Grass and that is
> taking a really long time.
>> Many thanks for your help and input,
>> Wesley
>> Wesley Roberts MSc.
>> Researcher: Earth Observation (Ecosystems)
>> Natural Resources and the Environment
>> CSIR
>> Tel: +27 (21) 888-2490
>> Fax: +27 (21) 888-2693
>> "To know the road ahead, ask those coming back."
>> - Chinese proverb
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean. MailScanner thanks Transtec Computers for their support.
