[gdal-dev] python-gdal ComputStatistics return just two values
Even Rouault even.rouault at mines-paris.org
Fri Mar 27 14:45:05 EDT 2009
Hi Ivan,
I don't think there's a bug.
The C API for ComputeBandStats is :
CPLErr CPL_DLL CPL_STDCALL
GDALComputeBandStats( GDALRasterBandH hBand, int nSampleStep,
                             double *pdfMean, double *pdfStdDev,
                             GDALProgressFunc pfnProgress,
                             void *pProgressData );
So, the python API is consistant with it.
So it is expected that "bd1.SetStatistics(bd2.ComputeBandStats())" will fail
as it is provided with 2 values instead of the expected 4.
Best regards,
Even
Le Friday 27 March 2009 19:02:14 Lucena, Ivan, vous avez écrit :
> Hi there,
> I believe that ComputeBandStats() should return 4 values min, max, mean and
> stddev) [1] but the Python API is returning just mean and stddev.
> python:
> >>> bd.ComputeBandStats()
> (9.0071713001936118, 11.350094331448236)
> >>> bd.ComputeRasterMinMax()
> (-1.7899999618530273, 31.149999618530273)
> gdalinfo:
> Band 1 Block=360x1 Type=Float32, ColorInterp=Gray
>   Min=-1.790 Max=31.150
>   Minimum=-1.790, Maximum=31.150, Mean=9.007, StdDev=11.350
>   Unit Type: unspecified
>   Metadata:
>     STATISTICS_MINIMUM=-1.789999961853
>     STATISTICS_MAXIMUM=31.14999961853
>     STATISTICS_MEAN=9.0071713001936
>     STATISTICS_STDDEV=11.350094331448
> Is that a bug?
> See what happens in that case:
> Traceback (most recent call last):
>   File "<interactive input>", line 1, in <module>
>   File "E:\Python25\Lib\site-packages\osgeo\gdal.py", line 729, in
> SetStatistics return _gdal.Band_SetStatistics(*args)
> TypeError: Band_SetStatistics() takes exactly 5 arguments (2 given)
> My best regards,
> Ivan
> [1] http://www.gdal.org/gdal_8h.html#a93b6b6ea6e71017ce25524e1a9ef1e3
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
