[gdal-dev] python-gdal ComputStatistics return just two values
Ivan Lucena
ivan.lucena at pmldnet.com
Fri Mar 27 18:19:48 EDT 2009
D'accord.
Even Rouault wrote:
> Le Friday 27 March 2009 20:05:11 Lucena, Ivan, vous avez écrit :
>> Even,
>> I see. You are right. With the absence of ComputeRasterStatistics() I got
>> confused and I made the wrong
>> assumption. BTW, why there is no wrapper for ComputeRasterStatistics()? That
> would work then:
>>>>> bd1.SetStatistics(bd2.ComputeRasterStatistics())
> Because you don't use the latest and greatest GDAL ;-)
> Extract from swig/include/Band.i from SVN head:
> /* Interface method added for GDAL 1.7.0 */
> %apply (double *OUTPUT){double *min, double *max, double *mean, double
> *stddev};
> %apply (IF_ERROR_RETURN_NONE) { (CPLErr) };
> CPLErr ComputeStatistics( bool approx_ok, double *min = NULL, double *max =
> NULL, double *mean = NULL, double *stddev = NULL,
> GDALProgressFunc callback = NULL, void* callback_data=NULL){
> return GDALComputeRasterStatistics( self, approx_ok, min, max, mean,
> stddev, callback, callback_data );
> %clear (CPLErr);
>> Not a big deal. The work around is easy.
>> Thank you very much,
>> Ivan
>>> -------Original Message-------
>>> From: Even Rouault <even.rouault at mines-paris.org>
>>> Subject: Re: [gdal-dev] python-gdal ComputStatistics return just two
>>> values Sent: Mar 27 '09 18:45
>>> Hi Ivan,
>>> I don't think there's a bug.
>>> The C API for ComputeBandStats is :
>>> CPLErr CPL_DLL CPL_STDCALL
>>> GDALComputeBandStats( GDALRasterBandH hBand, int nSampleStep,
>>> double *pdfMean, double *pdfStdDev,
>>> GDALProgressFunc pfnProgress,
>>> void *pProgressData );
>>> So, the python API is consistant with it.
>>> So it is expected that "bd1.SetStatistics(bd2.ComputeBandStats())" will
>>> fail as it is provided with 2 values instead of the expected 4.
>>> Best regards,
>>> Even
>>> Le Friday 27 March 2009 19:02:14 Lucena, Ivan, vous avez écrit :
>>> > Hi there,
>>> > I believe that ComputeBandStats() should return 4 values min, max,
>>> > mean and stddev) [1] but the Python API is returning just mean and
>>> > stddev.
>>> > python:
>>> > >>> bd.ComputeBandStats()
>>> > (9.0071713001936118, 11.350094331448236)
>>> > >>> bd.ComputeRasterMinMax()
>>> > (-1.7899999618530273, 31.149999618530273)
>>> > gdalinfo:
>>> > Band 1 Block=360x1 Type=Float32, ColorInterp=Gray
>>> > Min=-1.790 Max=31.150
>>> > Minimum=-1.790, Maximum=31.150, Mean=9.007, StdDev=11.350
>>> > Unit Type: unspecified
>>> > Metadata:
>>> > STATISTICS_MINIMUM=-1.789999961853
>>> > STATISTICS_MAXIMUM=31.14999961853
>>> > STATISTICS_MEAN=9.0071713001936
>>> > STATISTICS_STDDEV=11.350094331448
>>> > Is that a bug?
>>> > See what happens in that case:
>>> > Traceback (most recent call last):
>>> > File "<interactive input>", line 1, in <module>
>>> > File "E:\Python25\Lib\site-packages\osgeo\gdal.py", line 729, in
>>> > SetStatistics return _gdal.Band_SetStatistics(*args)
>>> > TypeError: Band_SetStatistics() takes exactly 5 arguments (2 given)
>>> > My best regards,
>>> > Ivan
>>> > [1] http://www.gdal.org/gdal_8h.html#a93b6b6ea6e71017ce25524e1a9ef1e3
>>> > _______________________________________________
>>> > gdal-dev mailing list
>>> > gdal-dev at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
