[gdal-dev] Is it a big thing to change ECW to support 16-bit imagery?
Ivan Lucena ivan.lucena at pmldnet.com
Sat Mar 28 00:10:08 EDT 2009
Mo,
See, GDAL does not implement the code that actually reads the ECW
format. The GDAL ECW driver just make calls to a external library. That
library is provided by the company that holds the copyright for that
format [1]. So you would need to ask and negotiate with then first.
But I believe that they probably have thought about that before and
maybe that *is* a "big thing", as you said. It is not just a matter of
storing pixels values but it is matter of running a algorithm to
calculate the wavelets. Or maybe is just because that is how and why the
format was designed. I mean, for byte image.
But if they *do* decided to implement that change I believe it will be
pretty simple for anyone of the GDAL driver's developers to make the
necessary changes to adapt to it.
But like I said before, don't hold you breath waiting for that. I don't
think that there is a chance.
[1] http://www.gdal.org/frmt_ecw.html
My best regards,
Ivan
mohwawang wrote:
> Mateusz,
> License issue can be resolved through negotiation. Then back to the technique issue: Is it a big thing to change ECW to support 16-bit imagery?
> Mo
> --- On Fri, 3/27/09, Mateusz Loskot <mateusz at loskot.net> wrote:
>> From: Mateusz Loskot <mateusz at loskot.net>
>> Subject: Re: [gdal-dev] Is it a big thing to change ECW to support 16-bit imagery?
>> To: "mohwawang" <mohwawang at yahoo.com>
>> Cc: gdal-dev at lists.osgeo.org
>> Date: Friday, March 27, 2009, 7:31 PM
>> mohwawang wrote:
>>> Mateuse,
>>> So what's the answer to the "correct" question?
>> Read the license.
>> Best regards,
>> Mateusz Loskot, http://mateusz.loskot.net
>> Charter Member of OSGeo, http://osgeo.org
> gdal-dev mailing list
