[gdal-dev] suitable test viewer for new driver
fabrice martin fabrice_martin2 at yahoo.fr
Sat Mar 28 15:41:53 EDT 2009
I'm a bit off-topic, but is this new driver the  jpip driver described in RFC_24 (http://trac.osgeo.org/gdal/wiki/rfc24_progressive_data_support)? If so, that's great news, does it use Kakadu for its implementation ?
Best regards.
Norman Barker wrote:
> Hi,
> I have written a gdal driver and would like to hook this into an existing viewer (public domain) to demonstrate the code.  The driver makes a fair few changes to the GDAL API so it isn’t as simple as just adding to the format list.
> Would I be better to use openev or openev2, or perhaps a different viewer?  Any ideas are appreciated, I would like to use a viewer that compiles against the current GDAL trunk.
Norman,
In my opinion it is getting pretty hard to build OpenEV from source and
it's OpenGL tile based approach may not be very ammendable to the progressive
support you want to test.  I'd suggest qgis (http://www.qgis.org).
