[gdal-dev] How to use GDAL Library
Jürgen E. Fischer
jef at norbit.de
Mon Mar 30 09:55:18 EDT 2009
On Mon, 30. Mar 2009 at 13:22:46 -0000, Ajmeri Iqbal wrote:
> D:/QT_Projects/ImageRW/main.cpp:34: undefined reference to
> `GDALDataset::GetRasterCount()'
Are you using the C++ API directly? That won't work from MinGW unless
GDAL is also built with MinGW. The C-API will work.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
