[gdal-dev] How to use GDAL Library
Jürgen E. Fischer
jef at norbit.de
Tue Mar 31 04:19:08 EDT 2009
[what's your firstname btw?]
On Tue, 31. Mar 2009 at 06:01:51 -0000, Ajmeri Iqbal wrote:
> shell i continue with C-api or build GDAL library with MinGW and use C++-api?
http://trac.osgeo.org/gdal/wiki/FAQMiscellaneous#CAPIvsCAPI:
> If you intend writing code using GDAL/OGR that will not require
> recompilation when run against different GDAL/OGR versions, you should
> try to stick to the C API when possible. Although the changes in the
> C++ API are generally made in a upward compatible way, the C++ ABI
> might change from a minor release to another one (for example from
> GDAL 1.5.0 to GDAL 1.6.0) due to additions of new virtual methods, new
> member variables to core classes, etc.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
