[gdal-dev] Problem with old projection string
Frank Warmerdam
warmerdam at pobox.com
Mon May 4 11:58:01 EDT 2009
Derrick Hoffman wrote:
> //Get GDAL reprojection transform
> void * pTransformArg = GDALCreateReprojectionTransformer(sourceArray,
> destArray);
Derrick
Does the above function return a non-NULL result? Does the
GDALReprojectionTransform() function seem to be doing the right
thing (ie. success is TRUE and result coordiantes are geographic)?
> My problem is that when the dataset is opened, the projection string it
> reports is just “Local_CS[“”]”
> Any ideas on how I can get the projection for the file in a manner that
> my GDAL conversion will work, or an alternative method for converting?
It seems to me that the problem isn't specifically with the coordinate
reprojection, but with how the output file is created - a matter you
haven't described. What is the output format? How are you setting the
coordinate system on the output file? Possibly you will need to provide
more context.
I will say I don't see any inherent problem with the output coordinate
system definition you are using.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
