[gdal-dev] best method to check points in polygon?
Mateusz Loskot
mateusz at loskot.net
Wed May 6 12:41:37 EDT 2009
G. Allegri wrote:
> I need to check "points in polygon" over various thousands of points
> and regional scale polygons. A for loop iteration + intersect() over
> the points geometries is absolutely inefficient.
What you you need is OGRGeometry::Within or OGRGeometry::Contains,
not intersect.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
