[gdal-dev] where is the source code of gdaldem
mohwawang
mohwawang at yahoo.com
Wed May 6 15:29:45 EDT 2009
Even,
I understood. Thank you.
Mo
--- On Wed, 5/6/09, Even Rouault <even.rouault at mines-paris.org> wrote:
> From: Even Rouault <even.rouault at mines-paris.org>
> Subject: Re: [gdal-dev] where is the source code of gdaldem
> To: gdal-dev at lists.osgeo.org
> Cc: "mohwawang" <mohwawang at yahoo.com>
> Date: Wednesday, May 6, 2009, 2:38 PM
> Mo,
> If you read carefully the very top of the page, you'll see
> that the utility
> will only be available in GDAL 1.7.0, so it's normal you
> don't find it in
> gdal-1.6.0
> Mateusz also quoted http://trac.osgeo.org/gdal/ticket/2975. Currently,
> there
> is a discussion between the GDAL and GRASS projects about
> the proper
> licencing & copyright attribution ot this utility (that
> may be removed from
> GDAL depending on the outcome of the discussion). So I'd
> encourage you to
> avoid distributing or reusing the current source code in
> SVN until this
> ticket has been closed and we can confirm that X/MIT
> licence is appropriate.
> Thank you,
> Even
> Le Wednesday 06 May 2009 15:28:38 mohwawang, vous avez
> écrit :
> > Hi all,
> > According to http://www.gdal.org/gdaldem.html there is a utility
> program
> > gdaldem. But where is the source code? I could not
> find it in ~/apps in
> > gdal-1.6.0. Thank you for help.
> > Mo
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
