[gdal-dev] When does the env var GDAL_DATA get processed?
    Tamas Szekeres
    szekerest at gmail.com
    Thu May  7 18:43:06 EDT 2009
2009/5/7 brettwiesner <brettwiesner at gmail.com>
> Yes that's the error message. It goes on the say somthing about trying to
> find gcs.csv which is there but since it can't find the env var, it doesn't
> find the data. This is weird because I set the env var using the win32
> function SetEnvironmentVariable() before the call to OGRSpatialReference is
> made. Since I was setting the variable and getting this message I suspected
> that GDAL_DATA was being read by something at startup.
I'm afraid you won't be able to set the environment variable this way. GDAL
is using getenv() to retrieve the value which operated on a local copy of
the variables created when the process is started. By this means the env
variable should be set before the process is spawned.
> Is there some code I can write that can tell me what gdal thinks the
> GDAL_DATA env var is set to?
You should instead use SetConfigOption or PushFinderLocation (both exposed
to the SWIG API) for this purpose.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090508/5f10d8f7/attachment.html
