[Gdal-dev] Create HDF5 Problem
Sunny K
shkwak74 at nate.com
Wed May 13 05:37:40 EDT 2009
I want to create HDF5 format file.
So, I programmed as following C# source code.
But, when I call Create() method, the following error message was happend.
"GDALDriver::Create()... no create method implemted for this format"
I don't know that GDAL libray cannot support HDF5 creation or I used wrong
method.
I'd appreciate it if you would tell me some information to solve this
problem.
public void CreateData(string strPath)
OSGeo.GDAL.Driver drv = Gdal.GetDriverByName("HDF5");
int w = 512;
int h = 512;
Dataset ds = drv.Create(strPath, w, h, 1, DataType.GDT_Byte,
null); }
Best regards,
- sunny
View this message in context: http://n2.nabble.com/Create-HDF5-Problem-tp2880597p2880597.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
