[gdal-dev] gdalwarp for ED50 UTM zone 31N to WGS84
Jorge Arévalo jorge.arevalo at gmail.com
Wed May 13 18:38:56 EDT 2009
De nada :-). Y suerte
2009/5/14 Ragi Y. Burhum <ragi at burhum.com>
> Gracias Jorge
> 2009/5/13 Jorge Arévalo <jorge.arevalo at gmail.com>
>  Hello,
>> I'm from Spain, and I can confirm your parameters. These worked for me as
>> well.
>> Regards
>> Jorge
>> On Tue, May 12, 2009 at 1:03 AM, Ragi Y. Burhum <ragi at burhum.com> wrote:
>>> I was just sending this e-mail so that it can be searched through the
>>> archives. Thanks to Even Rouault for walking me through something that
>>> should have been obvious :)
>>> Originally, I was having trouble finding the right parameters for
>>> gdalwarp to be able to warp some imagery that I got from Spain. These were
>>> in ED50 / UTM zone 31N:
>>> rburhum at cuzconix:~/p_bug$ gdalinfo exported_from_original_sid_file.tif
>>> Driver: GTiff/GeoTIFF
>>> Files: exported_from_original_sid_file.tif
>>> Size is 6946, 4800
>>> Coordinate System is:
>>> PROJCS["ED50 / UTM zone 31N",
>>>     GEOGCS["ED50",
>>>         DATUM["European_Datum_1950",
>>>             SPHEROID["International 1924",6378388,297.0000000000014,
>>>                 AUTHORITY["EPSG","7022"]],
>>>             AUTHORITY["EPSG","6230"]],
>>>         PRIMEM["Greenwich",0],
>>>         UNIT["degree",0.0174532925199433],
>>>         AUTHORITY["EPSG","4230"]],
>>>     PROJECTION["Transverse_Mercator"],
>>>     PARAMETER["latitude_of_origin",0],
>>>     PARAMETER["central_meridian",3],
>>>     PARAMETER["scale_factor",0.9996],
>>>     PARAMETER["false_easting",500000],
>>>     PARAMETER["false_northing",0],
>>>     UNIT["metre",1,
>>>         AUTHORITY["EPSG","9001"]],
>>>     AUTHORITY["EPSG","23031"]]
>>> Origin = (327720.000000000000000,4730783.500000000000000)
>>> Pixel Size = (0.500000000000000,-0.500000000000000)
>>> Metadata:
>>>   AREA_OR_POINT=Area
>>> Image Structure Metadata:
>>>   INTERLEAVE=PIXEL
>>> Corner Coordinates:
>>> Upper Left  (  327720.000, 4730783.500) (  0d53'46.94"E, 42d42'34.10"N)
>>> Lower Left  (  327720.000, 4728383.500) (  0d53'49.56"E, 42d41'16.35"N)
>>> Upper Right (  331193.000, 4730783.500) (  0d56'19.50"E, 42d42'36.88"N)
>>> Lower Right (  331193.000, 4728383.500) (  0d56'22.08"E, 42d41'19.12"N)
>>> Center      (  329456.500, 4729583.500) (  0d55'4.52"E, 42d41'56.62"N)
>>> Band 1 Block=6946x1 Type=Byte, ColorInterp=Red
>>> Band 2 Block=6946x1 Type=Byte, ColorInterp=Green
>>> Band 3 Block=6946x1 Type=Byte, ColorInterp=Blue
>>> In order to get it to work correctly, I had to use the right +towgs84
>>> parameters from
>>> http://earth-info.nga.mil/GandG/coordsys/onlinedatum/CountryEuropeTable.html. Although the table showed  -84 (+/-5), -107(+/-6), -120 (+/-3), for my own
>>> purposes -87, -98, -121 seemed to work best based on my source data.
>>> so the command line would be:
>>>  gdalwarp -s_srs "+proj=utm +zone=31 +ellps=intl +units=m
>>> +towgs84=-87,-101,-121 +no_defs" -t_srs EPSG:4326
>>> exported_from_original_sid_file.tif testout.tif
>>> Hope this helps someone else,
>>> - Ragi
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090514/70d96213/attachment.html
