[gdal-dev] Relax KML driver about xmlns
Even Rouault even.rouault at mines-paris.org
Wed May 20 13:49:04 EDT 2009
I've verified that the KML driver only looks for a known version (2.0, 2.1,
2.2), but doesn't make any other use of it, so we could reasonably implement
Christopher's proposal : "if the document element _is_ kml and the version
_is not_ found or not recognized OGR issues a warning and proceeds as if the
KML were 2.2"
Le Wednesday 20 May 2009 19:34:26 Christopher Condit, vous avez écrit :
> Hi Mateusz-
> > Would it make sense to relax a bit the KML driver here [1] so it
> > accepts <kml> root without xmlns attribute?
> The problem is that the KML schema had many iterations before becoming
> an OGC standard and in some cases those schema changes are not backward
> compatible. The namespace exists to alert the client as to which version
> of the schema to expect. However - I'm not sure what portion of the
> schema that OGR uses actually changed.
> > One user reported to me that he is not able to read this file [2]
> > using OGR KML driver and I found this is because of missing xmlns in
> > <kml> root element. The KML was produced by some unknown
> > software shipped with some GPS logger.
> > I'm wondering if there are more KML generators in use that
> > produce <kml> element without xmlns attribute.
> I see your point here. I think the onus is the software generating the
> KML as it is part of the specification. How about this: if the document
> element _is_ kml and the version _is not_ found or not recognized OGR
> issues a warning and proceeds as if the KML were 2.2?
> -Chris
> Christopher Condit
> condit at sdsc.edu
> (858) 822-5483
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
