[gdal-dev] Local coordinate system and proj4
Bryan Keith
bryan at ideotrope.org
Wed May 20 17:08:45 EDT 2009
Martin,
That did it. It is in Nevada. I don't know if it's a stateplane
coordinate system with an unusual false easting and northing or something
else.
I replaced "Local" with "Transverse_Mercator". The reprojection worked.
I compared the results with what ArcMap calculates, and the greatest
difference is < 1 cm. That's good enough for what I'm doing. Thank you
for the help.
Bryan
> Looks to me like it is a state plane projection for somewhere in Nevada.
> Maybe try using Transverse Mercator as the PROJCS. I'm not a GIS pro
> though
> so take my advice with a grain of salt.
> Martin
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Bryan Keith
> Sent: Wednesday, May 20, 2009 2:11 PM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] Local coordinate system and proj4
> Hello,
> I've been sent an ESRI coordinate system file (.prj) that looks like this:
> PROJCS["Unknown",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984
> ",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.01745329
> 25199433]],PROJECTION["Local"],PARAMETER["False_Easting",68396.30349583333],
> PARAMETER["False_Northing",207061.59375],PARAMETER["Scale_Factor",1.0],PARAM
> ETER["Azimuth",0.0],PARAMETER["Longitude_Of_Center",-117.0],PARAMETER["Latit
> ude_Of_Center",41.29],UNIT["Foot_US",0.3048006096012192]]
> When I try to use this definition in proj4 using ogr tools, I get this
> error:
> ERROR 6: No translation for Local to PROJ.4 format is known.
> Is there a way to use this projection information with proj4? ESRI ArcMap
> seems to be to translate from these coordinates to lat-long WGS84.
> Bryan
> gdal-dev mailing list
