[gdal-dev] HDF5 link problem
Tamas Szekeres
szekerest at gmail.com
Sat May 23 07:58:35 EDT 2009
I don't think we explicitly set the 1.6 compatibility mode in the builds. I
assume the 1.8 mode is the default setting.
Best regards,
Tamas
2009/5/23 Francesco P. Lovergine <frankie at debian.org>
> On Tue, May 19, 2009 at 06:57:21PM +0200, Tamas Szekeres wrote:
> > Bruce,
> > I'm using hdf5-1.8.2 and it seems working well.
> > You can obtain the binaries and build SDKs from here:
> > http://vbkto.dyndns.org:1280/sdk/Default.aspx
> > Best regards,
> > Tamas
> Note that 1.8 can be built in 1.6 compatibility mode or not.
> Maybe that does the difference...
> > 2009/5/19 Clay, Bruce <bclay at ball.com>
> > > I downloaded the latest version of HDF5 from
> > > ftp://ftp.hdfgroup.org/HDF5/current/bin/windows/ and am trying to
> build
> > > HDF5 support into GDAL 1.6.1.
> > > Unfortuneately when I enable HDF5 suuport in the nmake.opt I get
> unresolved
> > > link errors the interesting thing is that the errors are not just for
> HDF5.
> > > I do have SDE enabled and GRIB is enabled by default. I don’t know
> that the
> > > first unresolved is but all of the error go away if I take HDF5 out of
> the
> > > build.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090523/379ae263/attachment.html
