[gdal-dev] ogr2ogr encoding
Alexandre Dube
adube at mapgears.com
Wed May 27 08:01:15 EDT 2009
I need to add a dbf file to a postgis database. I use ogr2ogr with
the postgresql driver for that. Problem is, I get an encoding error :
=== ERROR START ===
Warning 1: PQescapeString(): incomplete multibyte character
input: 'Río'
got: 'Río '
ERROR 1: INSERT command for new feature failed.
ERROR: invalid byte sequence for encoding "UTF8": 0xed6f20
HINT: This error can also happen if the byte sequence does not match
the encoding expected by the server, which is controlled by
"client_encoding".
=== ERROR END ===
I tried to set the database encoding of my database with \encoding or
SET CLIENT_ENCODING TO 'encoding'; but it's not working. I tried latin1
and UTF8. What am I missing ?
Alexandre Dubé
Mapgears
www.mapgears.com
