Re: [gdal-dev] non-fully conform output of gdalwarp
Lucena, Ivan
ivan.lucena at pmldnet.com
Fri May 29 07:49:01 EDT 2009
If you use DATUM["GRS_1980" instead of DATUM["D_GRS_1980" it might work. See http://spatialreference.org for
more info.
> -------Original Message-------
> From: Matthieu Rigal <rigal at rapideye.de>
> Subject: [gdal-dev] non-fully conform output of gdalwarp
> Sent: May 29 '09 05:11
> Hi guys,
> Working with GDAL 1.6.1, I got some strange result. It is not very
> compromising, because the result is OK, but it shall be enhanced, or I shall
> learn how to use it.
> giving the following command :
> gdalwarp -t_srs
'PROJCS["ETRS89_GRS80_3",GEOGCS["LUA_ETRS89",DATUM["D_GRS_1980",SPHEROID["GRS_1980",6378137.0,2
98.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Merc
ator"],PARAMETER["False_Easting",3500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",1
5.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]'
> 8_WGS84.tif 8_ETRS89.tif
> will create the desired file, and project it fine, but doing :
> gdalinfo 8_ETRS89.tif
> will show :
> DATUM["unknown",
> SPHEROID["unnamed",6378137,298.2572221010042]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",15],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",3500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]]]
> Why is the Datum set to unknown and the spheroid to unnamed ?
> It also causes some other software to warn that the projection is not the same
> (as the desired)...
> Best regards,
> Matthieu
> Matthieu Rigal
> Product Development
> RapidEye AG Tel: +49-(0)3381-89 04 331
> Molkenmarkt 30 Fax: +49-(0)3381-89 04 101
> 14776 Brandenburg/Havel
> Germany http://www.rapideye.de
> RapidEye AG
> Molkenmarkt 30
> 14776 Brandenburg an der Havel
> Germany
> Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
> Management Board/Vorstand: Wolfgang G. Biedermann
> Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Axel Schmalz
> Commercial Register/Handelsregister Potsdam HRB 17 796
> Tax Number/Steuernummer: 048/100/00053
> VAT-Ident-Number/Ust.-ID: DE 199331235
> DIN EN ISO 9001 certified
> Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
> Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
> E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
> Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
> die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
> The information in this e-mail is intended for the named recipients
> only. It may contain privileged and confidential information. If you
> have received this communication in error, any use, copying or
> dissemination of its contents is strictly prohibited. Please erase all
> copies of the message along with any included attachments and notify
> RapidEye AG or the sender immediately by telephone at the number
> indicated on this page.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
