[gdal-dev] Building a Mercator Image from Un-projected data.. Major confusion and help requested.
Christopher Barker Chris.Barker at noaa.gov
Mon Nov 2 16:38:45 EST 2009
Cassanova, Bill wrote:
> I am looking to gain a better understanding of how I can use GDAL to
> build a Mercator Image from un-projected data.
Do you need to write your own code for this?, or could you just use the
  gdalwarp utility? (maybe after converting to a format gdal knows).
If you do need your own code, you might look at the gdalwarp code.
Which brings up a question I could answer by reading the source, but
since I'm here:
Is the core warping functionality in the GDAL API (and wrapped for
Python?), or in the gdalwarp code -- I may need to do some warping in
code as well.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
