[gdal-dev] SQL results truncated
Clay, Bruce bclay at ball.com
Wed Nov 4 12:25:13 EST 2009
It seems like I encountered this problem before but I can not find any
information about it now.
If I run a SQ script like the following
Select * from
 (Select MIN_LAT - (round((MIN_LAT - LATITUDE) / (MAX_LAT - MIN_LAT) *
1728.497600)) * 0.000579 LAT2,
         MAX_LON - (round((LONGITUDE - MAX_LON) / (MIN_LON - MAX_LON) *
1814.921600)) * 0.000551 LON2,
         Round(sum(TRACK_SIZE) / 1.000000) CONFIDENCE,
         max(B_TEMP) Intensity,
         min(TO_CHAR(DATE_TIME, 'MM-DD-YYYY HH24:MI:SS')) DATE_TIME
    FROM
       WACDS.MODIS_ACTIVE_FIRE WHERE
          LATITUDE BETWEEN MIN_LAT AND MAX_LAT AND
          LONGITUDE BETWEEN MIN_LON AND MAX_LON AND
          DATE_TIME BETWEEN TO_DATE('03/01/2007 00:00:00' , 'MM-DD-YYYY
HH24:MI:SS') AND
                            TO_DATE('04/30/2007 23:59:59' , 'MM-DD-YYYY
HH24:MI:SS') AND
          CONFIDENCE > 1.000000
    GROUP BY
        round((MIN_LAT - LATITUDE) / (MAX_LAT - MIN_LAT) * 1728.497600),
1814.921600))
  where
    (CONFIDENCE * 1.000000) > 1.000000
  ORDER BY DATE_TIME
From sqlPal I get LAT2 and LON2 data back as doubles
If I run it through OGR ExecuteSql the LAT2 and LON2 data comes back as
integers and can not be used to plot the data
OGRFieldDefn *fieldDef = featureDef->GetFieldDefn(fieldIndex);
if (fieldDef != NULL)
      fieldType = fieldDef->GetType();
Returns type integer
And both
 const char *latStr = (char *)feature->GetFieldAsString("LAT2");
  double latitude = feature->GetFieldAsDouble("LAT2");
return(only the whole portion of what I see in sqlPal.
Does anyone see / know what might be going wrong?
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091104/777ad99a/attachment.html
