[gdal-dev] gdalwrap support for non geo referenced images
vvv jjj vvvjjj0 at yahoo.co.in
Fri Nov 6 05:56:06 EST 2009
Thanks Chaitanya.
One more doubt.
I would like to know whether any GDAL application supports resizing an image (with no projection details) using lanscoz resampling method. I looked at gdal translate but could not find the option to change the resampling method. Kindly let me know if there is any option.
Thanks and Regards
J.Viswanath
--- On Thu, 5/11/09, Chaitanya kumar CH <chaitanya.ch at gmail.com> wrote:
> From: Chaitanya kumar CH <chaitanya.ch at gmail.com>
> Subject: Re: [gdal-dev] gdalwrap support for non geo referenced images
> To: "vvv jjj" <vvvjjj0 at yahoo.co.in>
> Cc: gdal-dev at lists.osgeo.org
> Date: Thursday, 5 November, 2009, 5:15 PM
> Viswanath,
> gdalwarp is used to reproject an image from one projection
> to another.
> With no projection information or GCPs with your tiff there
> is no way it can do that.
> Perhaps you are looking for gdal_translate ( http://www.gdal.org/gdal_translate.html
> On Thu, Nov 5, 2009 at 4:32 PM,
> vvv jjj <vvvjjj0 at yahoo.co.in>
> wrote:
> Hello
>    Im trying to resample a simple tiff file which do not
> contain any georeference data using gdalwrap. The gdalwrap
> is showing the following message.
> ERROR 1: Unable to compute a transformation between
> pixel/line
> and georeferenced coordinates for myfile.tif.
> There is no affine transformation and no GCPs.
> What does it mean? Does it mean gdalwrap do not support
> images with no geo reference details or anything else. Or
> did I missed anything in using gdalwrap.
> Thanks in advance.
> J.Viswanath
>       Connect more, do more and share more with Yahoo!
> India Mail. Learn more. http://in.overview.mail.yahoo.com/
> gdal-dev mailing list
> Best regards,
> Chaitanya kumar CH.
      Connect more, do more and share more with Yahoo! India Mail. Learn more. http://in.overview.mail.yahoo.com/
      The INTERNET now has a personality. YOURS! See your Yahoo! Homepage. http://in.yahoo.com/
