Re: [gdal-dev] Re: JAVA API - Performance
Ivan
ivan.lucena at pmldnet.com
Tue Nov 10 15:54:06 EST 2009
Caio Simone,
I just downloaded imageio-ext to check how it does that but it looks like I don't need to do that now, I can take you report instead. Thank you very much. I will take a look on array pinning for a start.
I translated the GDAL Proximity [1] code to Java and I timed both of then with the same input, a 1024x1024 byte image with just one pixel as feature at the center of the image.
It took 0.3 seconds in C++ and 1.5 seconds in Java!
I then translated the buffers to regular arrays and it went down a little bit, 1.3 seconds.
It is still a big disadvantage. I believe that the buffer-to-buffer translation is the guilt time waster in that case.
[1] http://trac.osgeo.org/gdal/browser/trunk/gdal/alg/gdalproximity.cpp
My best regards,
Ivan
> -------Original Message-------
> From: Simone Giannecchini <simone.giannecchini at geo-solutions.it>
> Subject: Re: [gdal-dev] Re: JAVA API - Performance
> Sent: Nov 10 '09 12:36
> Ciao Even,
> just wanted to add my 2 cents.
> As you know for the imageio-ext project we have been using the
> GDAL-JNI bindings (actually a modified version of them) for a while in
> order to allow Java users to leverage on GDAL using the ImageIO
> framework which standard in Java.
> This way we also enabled GeoTools and GeoServer to use GDAL as a datasource.
> In the past I have done quite some performance tests to add some
> new/different methods to them and I can summarise our findings as
> follows:
> - DirectByteBuffer vs regular arrays -
> DBB is expensive to allocate but prevent the VM from performing copies
> when having to move data to and from java and native code since they
> live on the native space not on the java heap; On the other side the
> regular arrays are fast to allocate but they are "usually" copied when
> moved across from/to java and native code since the JVM cannot leave
> the native code mess with the java heap space since the garbage
> collector would not be very happy about that. I said "usually" since
> there is a technique called array pinning that we can suggest the JVM
> to use to avoid the copy of regular array; however this mechanism is
> not guaranteed to be implemented and/or to work on each call (same
> reason as above, GC is not happy about this technique).
> If you can pool the DBB and/or use a few large DBB, where the cost of
> the copy would overcome the cost of its creation then DBB are much
> better than regular arrays. As an instance I noticed that using when
> reading striped tiff files regular arrays where faster, but as the
> tile size increases (and therefore the cost of a copy overcomes the
> cost of a DBB creation) the DBB performs much better
> - DirectByteBuffer and the impact on some JVM -
> Now in the past we decided to stick with DBB and give
> GeoServer/GeoTools users the capability to retile data on the fly.
> However lately, during the WMS performance shootout we noticed on some
> linux machines JVm soldi crashed, not nice (means restarting the
> GeoServer!!!).
> We investigated a bit in depth and the problem was that somehow the
> JVM was failing to allocate some internal images during the rendering
> process and then dying with a NullPointerException (apparently the SUN
> Java2D engineers did not use to check for out of memory errors in the
> java native space). Well, what happens is that if you use too much of
> the Java native space for your own objects, it is likely that the JVM
> itself will start to malfunction (you can find articles on the web on
> the memory model of a Java process, I don't think I am good enough to
> explain it ) since it cannot allocate its own objects.
> In the end we decide to leave DBB and go back to regular arrays with
> array pinning. This ensured us robustness and we did not see much
> performance degradation (which means that array pinning in the end
> works). This has been implemented by modifying the SWIG bindings for
> GDAL in order to use a byte array instead of a DBB and then use
> ByteArray utils to convert between different native type (short, int,
> etc..).
> - Conclusion -
> We might want to spend some time in the mid term to contribute some of
> this work back (or probably provide funding), but anyway, it would be
> great to have the capability to switch between DBB and regular arrays
> since both have flaws.
> However atm if I were asked I would say to go with regular arrays as
> we do in the imageio-ext project.
> Ciao,
> Simone.
> Ing. Simone Giannecchini
> GeoSolutions S.A.S.
> Founder - Software Engineer
> Via Carignoni 51
> 55041 Camaiore (LU)
> Italy
> phone: +39 0584983027
> fax: +39 0584983027
> mob: +39 333 8128928
> http://www.geo-solutions.it
> http://geo-solutions.blogspot.com/
> http://simboss.blogspot.com/
> http://www.linkedin.com/in/simonegiannecchini
> On Tue, Nov 10, 2009 at 12:00 PM, Even Rouault
> <even.rouault at mines-paris.org> wrote:
> > Selon Ivan <ivan.lucena at pmldnet.com>:
> > Ivan,
> > thanks for your testing (CC'ing the list as it is of general interest).
> > Actually, I also read on some sites that using ByteBuffer object versus regular
> > Java arrays is not always a win. Plus the fact that we must use a direct buffer
> > that has an extra allocation cost according to the Javadoc. So ByteBuffer might
> > be interesting if you just want to pass big arrays between native code, for
> > example if you read an array from a dataset and then write it to another one
> > without accessing it from the Java side. When you mention that accessing through
> > the byte[] array was faster, did you get it with the array() method instead ?
> > I'm wondering what the performance overhead of this call is.
> > As ByteBuffer is not at all a requirement for the interface with the native
> > code, it would be technically possible to add an alternative API that would use
> > the regular Java array types.
> > Would you mind opening an enhancement ticket about that ? Thanks
> > Even
> >> Even,
> >> I did some test with the GDAL Java API and some simple raster operations
> >> like the GDAL Proximity algorthm and I noticed that the performance while
> >> accessing pixels with <type>Buffer.get(i), <type>Buffer.put(i,value) is not
> >> as good as if you copy then to (or from) a "regular" array, like float[],
> >> double[], integer[] and byte[].
> >> The reason for that is obvious, get() and put() are funtion calls and
> >> contains a lot of code for range check.
> >> If I understand it correctly, ByteBuffer is the ideal or maybe the only
> >> way to get access to Buffers from C libraries thought a Java wrapper. But
> >> do you it would be possible to incapsulate the buffer conversion at the
> >> wrapper code so that users would be able to read and write direct to
> >> regular Java arrays?
> >> Just a suggestion,
> >> Ivan
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
