[Gdal-dev] python bindings, no netcdf support
HesselWinsemius
h.c.winsemius at gmail.com
Wed Nov 11 05:12:30 EST 2009
>I'm also not sure if GDAL supports NetCDF4 directly. It looks like the
>NetCDF driver is for NetCDF3. If you're lucky, NetCDF4 files might be
>accessible in GDAL using the HDF5 driver...
I will try to write files directly with the netcdf4-python module instead of
through gdal. Building from scratch looks too complicated to me.
View this message in context: http://n2.nabble.com/python-bindings-no-netcdf-support-tp3972664p3985482.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
