[gdal-dev] Re: gdal to define projection, EPSG:3412
Thu Nov 12 08:49:24 EST 2009
Hermann Peifer wrote:
> John Callahan wrote:
>> Thanks for responding Hermann. Yes, I tried using -s_srs EPSG:3412 as
>> well as the full PROJ4 string with the same result. When specifying
>> -s_srs, does gdalwarp ignore (override) the project information in the
>> hdr file?
> Hmm. AFAIK: gdal_translate -a_srs does override the file's projection
> information. I have a random.tif in LAEA projection (EPSG:3035), so I
> tried the following with gdal 1.6.2:
> gdal_translate random.tif out1.tif -a_srs EPSG:3412  # this results in [1]
> gdal_translate random.tif out2.tif -a_srs "+proj=stere +lat_0=-90
> +lat_ts=-70 +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378273 +b=6356889.449
> +units=m +no_defs"  # this gives [2]
> To me as an innocent GDAL user, this behaviour looks similar to
> http://trac.osgeo.org/gdal/ticket/3016. I might be wrong, though, in
> particular as you wrote that using the PROJ.4 string didn't help (and
> your source file isn't a GeoTIFF in the first place).
Hermann,
I have confirmed this problem and filed it as:
   http://trac.osgeo.org/gdal/ticket/3220
It is presumably a problem with translation of a specific projection method,
possibly in libgeotiff itself.
Best regards,
