[gdal-dev] Return codes in gdalwarp
Michal Migurski
mike at stamen.com
Fri Nov 13 02:28:23 EST 2009
Hello,
I think this is a bug report, or maybe a feature request.
I'm writing a script that shells out to gdalwarp. The GTiff files that
I might see as input to this script include palette and non-palette
images, and I'd like to be able to reliably compress the output
without human intervention.
Initially, I tried -co COMPRESS=JPEG on everything in the hopes that
gdalwarp would perform the necessary internal conversions to beat the
output into a JPEG. This didn't work with palette images, for which I
got an error like: "ERROR 1: JPEGSetupEncode:PhotometricInterpretation
3 not allowed for JPEG"
Then I tried setting up a loop that tries JPEG first followed by LZW,
but here I ran into difficulty recognizing a failure. The return code
for the palette images with all the errors is still 0, just like the
return code for a successful warp. The destination image is also
populated, so it's not possible to check for existence to determine
success.
What I'd love to see is a modification to the command-line behavior of
gdalwarp so it can be better used in a scripted setting, where
automated ways of detecting failure that don't require reading the
error output strings would be incredibly helpful. Ideally, choosing an
incompatible creation option would cause a non-zero exit and wouldn't
create the destination file.
-mike.
michal migurski- mike at stamen.com
415.558.1610
