[gdal-dev] tab delimited to shapefile
Clay, Bruce
bclay at ball.com
Wed Nov 18 11:09:57 EST 2009
Is there any way to use ogr2ogr to convert tab-delimited data such as
the geoname dot org files into shapefiles short of converting all tabs
to commas?
I created a VRT file that works with CSV files but I can not find any
way to convert tab-delimited data.
Bruce
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091118/ae1e7c19/attachment.html
