[gdal-dev] Problems with TIFF internal symbols
Francesco P. Lovergine frankie at debian.org
Fri Nov 20 01:24:29 EST 2009
On Fri, Nov 20, 2009 at 11:17:51AM +0800, Emmanuel Christophe wrote:
> Hi,
> I took a bit more time to investigate this and came out with a minimal
> test case to reproduce that (using only gdal). The context is a
> project using gdal AND some specific geotiff methods thus requiring
> both for linking.
> Since gdal 1.6 on Debian, the option with-hide-internal-symbols is
> used which appears to cause segmentation fault when reading geotiff
> files.
> The test program (also attached):
> #include "gdal.h"
> int main(int argc, char * argv[])
>   GDALAllRegister();
>   GDALOpen(argv[1], GA_ReadOnly );
> It is compiled using cmake with the following CMakeLists.txt:
> FIND_PATH(GDAL_INCLUDE_DIR gdal.h /usr/include/gdal)
> FIND_LIBRARY(GDAL_LIBRARY NAMES gdal)
> FIND_LIBRARY(TIFF_LIBRARY NAMES tiff)
> FIND_LIBRARY(GEOTIFF_LIBRARY NAMES geotiff)
> INCLUDE_DIRECTORIES(${GDAL_INCLUDE_DIR})
> ADD_EXECUTABLE(gdalHideSymbols gdalHideSymbols.cxx)
> TARGET_LINK_LIBRARIES(gdalHideSymbols ${TIFF_LIBRARY}
> ${GEOTIFF_LIBRARY}  ${GDAL_LIBRARY})
> I'm trying that using an updated debian testing with the official
> packages for tiff, geotiff, gdal. Just 'cmake .', then 'make'
> The segfault can be reproduced using a geotiff image, for example:
> http://hg.orfeo-toolbox.org/OTB-Data/raw-file/51234ada686c/Input/ROI_QB_MUL_4.tif
> It doesn't happen when the link to the geotiff library is removed.
> Emmanuel
Linking order does matter, I suspect. I wonder if gdal should use
versioned symbols at linking time on Debian to avoid such breakages
at all.
