[gdal-dev] Reading the data 'backwards'
Even Rouault
even.rouault at mines-paris.org
Fri Nov 20 13:29:30 EST 2009
tasmith3 at rockwellcollins.com a écrit :
Sometimes, it is desirable for GDAL not try to be too smart ;-)
However I think you can achieve what you want if you provide the buffer
with the right offset and a negative nLineSpace parameter. Something
like that (untested !) :
void* pBuffer = malloc(width * height);
poBand->RasterIO(GF_Read, 0, 0, width, height, pBuffer + width * (height
- 1), width, height, GDT_Byte, 1, -width)
> I work with code that handles data in a particular way. Instead of
> using the top-left corner as the origin, it uses the bottom left. It
> treats the data as if it's sitting in quadrant 1 on an X-Y plane with
> the bottom left corner sitting on the origin. The code expects me to
> read in the data from the file starting with the 'first' row (the
> bottom row) to the top row (the 'last' row) from left to right. If my
> image has n rows and m columns, could I do something like this...?
> RasterIO( GF_Read, 0, n, m, n, ...)
> and would GDAL be smart enough to know that since I'm placing my
> origin at the bottom left corner, it needs to read backwards or 'up'
> the image? If it can't, that's ok - I'll just have to do some post
> processing on the output buffer after the read. Changing the code
> around so it treats the top left corner as the origin isn't an option.
> I don't have that kind of authority and it'd be a massive change.
> Thanks,
> Todd
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
