[gdal-dev] /usr/lib/libexpat.so: could not read symbols: File in wrong format
Stephen Williams williams at csr.utexas.edu
Fri Nov 20 20:56:00 EST 2009
yep, you are right.  which is what i thought too and did the same thing
you suggested.  unfortunately the same thing happens.  same error at the
same location during make.
Kyle Shannon wrote:
> As Even wrote to me some time ago:
>     My guess is that /usr/lib/libexpat.so is a 32bit library. Maybe
>     there's
>     a /usr/lib64/libexpat.so on your system ? I'm not sure of the
>     filesystem
>     layout of RedHat's 64bit systems.
>     If that's the case, use the --with-expat-lib= option of the
>     configure script.
> and I used --with-expat-lib=/usr/lib64 for the option.
> Kyle Shannon
> Physical Science Technician
> RMRS Fire Sciences Lab
> Fire, Fuels & Smoke - RWU 4405
> 5775 Highway 10 W.
> Missoula, MT 59808
> (406)646-6577
> kshannon at fs.fed.us <mailto:kshannon at fs.fed.us>
> ksshannon at gmail.com <mailto:ksshannon at gmail.com>
> On Fri, Nov 20, 2009 at 4:08 PM, Steve Williams
> <williams at csr.utexas.edu <mailto:williams at csr.utexas.edu>> wrote:
>     I am trying to compile gdal as per the instructions of the
>     developer of specialized remote sensing software called gamma
>     (http://www.gamma-rs.ch/).  The platform is a Dell T410 dual Xeon
>     processor system with 8GB of memory, running Redhat Enterprise
>     Linux (RHEL 5.4 x86_64).  The configure goes smoothly, but on the
>     make I am getting the error on the subject line and the make
>     fails.  The configure instructions are very specific from gamma:
>     ./configure --without-python --without-php --without-ruby
>     --without-perl --without-jasper \
>     --without-curl --without-odbc --with-png=internal
>     --with-libtiff=internal --with-libgeotiff=internal \
>     --with-jpeg=internal --with-sqlite=no --with-libz=internal
>     --without-cfitsio --with-gif=internal --without-netcdf \
>     --without-pg --without-hdf4 --without-hdf5 --without-geos
>      --enable-shared --prefix=/usr/local/gdal
>     the last few lines on the failed make are:
>     make[1]: Entering directory `/usr/local/src/gdal-1.5.4'
>     /bin/sh /usr/local/src/gdal-1.5.4/libtool --mode=link   g++
>     -I/usr/include -lsqlite3 -L/usr/lib -lexpat  -lm -lrt -ldl      -o
>     libgdal.la <http://libgdal.la>
>     /usr/local/src/gdal-1.5.4/frmts/o/*.lo
>     /usr/local/src/gdal-1.5.4/gcore/*.lo
>     /usr/local/src/gdal-1.5.4/port/*.lo
>     /usr/local/src/gdal-1.5.4/alg/*.lo
>     /usr/local/src/gdal-1.5.4/ogr/ogrsf_frmts/o/*.lo
>     ./ogr/ogrgeometryfactory.lo ./ogr/ogrpoint.lo ./ogr/ogrcurve.lo
>     ./ogr/ogrlinestring.lo ./ogr/ogrlinearring.lo ./ogr/ogrpolygon.lo
>     ./ogr/ogrutils.lo ./ogr/ogrgeometry.lo
>     ./ogr/ogrgeometrycollection.lo ./ogr/ogrmultipolygon.lo
>     ./ogr/ogrsurface.lo ./ogr/ogrmultipoint.lo
>     ./ogr/ogrmultilinestring.lo ./ogr/ogr_api.lo ./ogr/ogrfeature.lo
>     ./ogr/ogrfeaturedefn.lo ./ogr/ogrfeaturequery.lo
>     ./ogr/ogrfeaturestyle.lo ./ogr/ogrfielddefn.lo
>     ./ogr/ogrspatialreference.lo ./ogr/ogr_srsnode.lo
>     ./ogr/ogr_srs_proj4.lo ./ogr/ogr_fromepsg.lo ./ogr/ogrct.lo
>     ./ogr/ogr_opt.lo ./ogr/ogr_srs_esri.lo ./ogr/ogr_srs_pci.lo
>     ./ogr/ogr_srs_usgs.lo ./ogr/ogr_srs_dict.lo
>     ./ogr/ogr_srs_panorama.lo ./ogr/ogr_srs_erm.lo ./ogr/swq.lo
>     ./ogr/ogr_srs_validate.lo ./ogr/ogr_srs_xml.lo
>     ./ogr/ograssemblepolygon.lo ./ogr/ogr2gmlgeometry.lo
>     ./ogr/gml2ogrgeometry.lo \
>               -rpath /usr/local/gdal/lib \
>               -no-undefined \
>               -version-info 13:4:12
>     libtool: link: rm -fr  .libs/libgdal.la.lnkscript
>     libtool: link: creating GNU ld script: .libs/libgdal.la.lnkscript
>     libtool: link: g++ -shared -nostdlib
>     /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crti.o
>     /usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtbeginS.o
>     .libs/libgdal.la.lnkscript  -lsqlite3 -L/usr/lib
>     /usr/lib/libexpat.so -lrt -ldl
>     -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2
>     -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64
>     -L/lib/../lib64 -L/usr/lib/../lib64 -lstdc++ -lm -lc -lgcc_s
>     /usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtendS.o
>     /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crtn.o
>      -Wl,-soname -Wl,libgdal.so.1 -o .libs/libgdal.so.1.12.4
>     collect2: ld returned 1 exit status
>     make[1]: *** [libgdal.la <http://libgdal.la>] Error 1
>     make[1]: Leaving directory `/usr/local/src/gdal-1.5.4'
>     make: *** [check-lib] Error 2
>     anybody seen this before or have a suggested fix?
>                       (O O)
>     ,-------------- oOO-(_)-OOo -------------,
>     |            Stephen Williams            |
>     |      Manager of Computer Services      |
>     |       Center for Space Research        |
>     |     University of Texas at Austin      |
>     |     3925 W. Braker Ln., Suite 200      |
>     |          Austin, TX 78759-5321         |
>     |    512.471.7235  512.471.3570 (fax)    |
>     |____________________ Oooo ______________|
>                   oooO   (   )
>                   \ (    (_/
>                    \_)
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
                    (O O)
 |            Stephen Williams            |
 |       williams at csr.utexas.edu          |
                oooO   (   )
                \ (    (_/
                 \_)
