[Gdal-dev] Looking for libecwj2.dll Win-64Bit version
Paul Meems
bontepaarden at gmail.com
Thu Oct 1 15:14:53 EDT 2009
Tamas, Mateusz and Rob,
Thanks for all your help.
It seems I can now successfully build to 64Bit.
In my first attempt I replaced Win32 with Win64 in the Preprocessor
Definitions.
That gave me the "unknown machine type will require custom 64 bit variables"
error.
When I restored Win32 I got the __asm keyword (Inline Assembler) error Rob
is talking about.
Now I added Win64 to the Preprocessor Definitions, so having both Win32 and
Win64 and it compiles OK.
My Preprocessor Definitions for Release|x64 is now:
QT_NO_DEBUG;NDEBUG;_WINDOWS;UNICODE;WIN32;WIN64;_MBCS;_UNICODE;LIBECWJ2;QT_DLL
I can't say I understand, but that's is my lack of understanding C++ ;) but
it works.
I haven't checked if it is a true 64Bit dll, because I don't know how to ;)
I'll now try and compile GDAL to 64Bit with this dll.
Paul
2009/10/1 iotc <iotc2000 at gmail.com>
> Hi Tamas and Mateusz
> Your time on helping us much appreciated. I am working with Paul in the
> MapWindow team and I implemented the macro fix to libecwj2 a few months ago
> (by strange coincidence I also chose NCS_ as the prefix).
> libecwj2.dll compiles fine in VS2008 in WIN32, but we are experiencing
> difficulties in making a x64 build. The main problem is that one of the key
> developers in MapWindow has moved on and the rest of us are not very clued
> up in C++.
> The error that Paul refers to occurs in lcms.h ("Little cms") in a call to
> the __asm keyword (Inline Assembler). I think that that could be fixed
> quite
> easily. However, we simply don't know what other changes need to be made to
> libecwj2 for a safe x64 build.
> Tamas - would it be possible to post that library again for a short time? -
> did you make #ifdef(WIN32) changes anywhere, and are there any special
> compilation flags that we need to change in VS2008?
> Best Regards
> Rob
> P.S. When I contacted Mark Sheridan of ERDAS in June about the legality of
> my changes, he hinted that development on the libecwj2 SDK is continuing
> but
> it would not be available as before. He wrote:
> "The older public 3.3 SDK is known to build with VS 2005, not sure about
> 2008, as we never ported that version internally. We do have a much newer
> version available to licensees with support for VS 2005/2008 in 32 and 64
> bit, as well as other enhancements like improved caching, GML in JP2
> support
> and JP2 opacity channels"
> http://n2.nabble.com/Looking-for-libecwj2-dll-Win-64Bit-version-tp3741096p3750840.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091001/bfbd29a5/attachment-0001.html
