[gdal-dev] Anti-Aliasing
Seth Price
seth at pricepages.org
Fri Oct 2 13:36:24 EDT 2009
Could you give an example of the problem? Anti-aliasing generally only
applies when you are going from vector line drawings to rasterized images.
If I was trying to smooth things I would first look at cubic or bilinear.
Any other resampling may enhance any noise in your image.
~Seth
On Fri, October 2, 2009 11:16 am, Chris Emberson wrote:
> I am looking for an anti-aliasing function to smooth out the pixellated
> effect between raster values. I have tried the various interpolation
> methods with gdalwarp and have also increased the resolution of the raster
> to try and minimise the effect, to no avail.
> Is this a function to be added soon?
> Thanks,
> Chris
> _________________________________________________________________
> Share your photos with Windows Live Photos Free.
> http://clk.atdmt.com/UKM/go/134665338/direct/01/_______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
