[gdal-dev] Anti-Aliasing
Adam Nowacki
nowak at xpam.de
Mon Oct 5 11:03:04 EDT 2009
Chris Emberson wrote:
> The rasters do have colour tables applied, that are expressed using RGB
> values, using gdaldem:
> 75% 107 0 0
> 50% 196 109 27
> 25% 247 195 72
> 0% 252 233 109
> nv 0 0 0 0
> They are not derived from vector data however. I am unsure of your
> requirement in terms of the source of the raster data. All of the pixel
> values have been created and either fall between the values of 1-4 or
> contain no data.
> The commands I am running on the files are:
> gdal_translate -of GTiff -co "TILED=YES" -b 1 -b 1 -b 1 fileA.asc fileB.tif
Upsample fileB.tif here:
gdalwarp -r bilinear -ts newwidth newheight fileB.tif fileB2.tif
Where newwidth and newheight are a few times larger than original.
> gdaldem color-relief fileB.tif rgb.txt fileC.tif -alpha
> gdalwarp -s_srs EPSG:27700 -t_srs EPSG:900913 -r bilinear fileC.tif
> fileD.tif
> an example of how the bilinear is working (fileD.tif) can be seen in the
> attached file. I have tried running running the gdalwarp command above
> prior to gdaldem but this makes little difference.
> TIA,
> Chris
> > Date: Mon, 5 Oct 2009 16:46:55 +0530
> > Subject: Re: [gdal-dev] Anti-Aliasing
> > From: chaitanya.ch at gmail.com
> > To: chrisemberson at hotmail.com
> > CC: seth at pricepages.org; gdal-dev at lists.osgeo.org
> > Chris,
> > The images look like they have a colour table instead of RGB bands.
> > Also, they seem to be converted from vector to raster. Correct me if I
> > am wrong.
> > Anti aliasing images with colour tables is a little more involved and
> > depends on the type of result required. Can you provide the source for
> > these images?
> > One method would be to convert the image into RGB, apply bilinear or
> > any other interpolation method, and convert it back to the colour
> > table from RGB. If the source is a vector, we can smooth the shapes by
> > using curves in place of straight lines.
> > On Mon, Oct 5, 2009 at 3:59 PM, Chris Emberson
> > <chrisemberson at hotmail.com> wrote:
> > > Seth,
> > > Thanks for the reply. The attached image hopefully will clarify the
> problem
> > > I am having. On the left of the image is the output I would like (I
> have
> > > produced this using a GIS). On the right is the output using mapnik and
> > > gdal. The problem is the pixellated effect between the raster
> values on the
> > > RHS.
> > > The GIS isn't that great as far as batch processing is concerned,
> hence why
> > > I am trying to use the GDAL utilities that ship with mapnik. The
> option in
> > > the GIS that produces the desired effect is "anti-aliasing (bilinear
> > > interpolation)", but it appears as though there is a more sophisticated
> > > smoothing algorithm being employed? I have tried running the various
> > > interpolation techniques with gdalwarp but none of them produce a crisp
> > > output. I have tried also increasing the resolution of the raster by 5x
> > > (both width and height) using "gdal_translate" and "-outsize 500%
> 500%"
> > > this doesn't help either.
> > > Any suggestions gratefully received,
> > > Chris
> > >> Date: Fri, 2 Oct 2009 12:36:24 -0500
> > >> From: seth at pricepages.org
> > >> CC: gdal-dev at lists.osgeo.org
> > >> Could you give an example of the problem? Anti-aliasing generally only
> > >> applies when you are going from vector line drawings to rasterized
> images.
> > >> If I was trying to smooth things I would first look at cubic or
> bilinear.
> > >> Any other resampling may enhance any noise in your image.
> > >> ~Seth
> > >> On Fri, October 2, 2009 11:16 am, Chris Emberson wrote:
> > >> > I am looking for an anti-aliasing function to smooth out the
> pixellated
> > >> > effect between raster values. I have tried the various interpolation
> > >> > methods with gdalwarp and have also increased the resolution of the
> > >> > raster
> > >> > to try and minimise the effect, to no avail.
> > >> > Is this a function to be added soon?
> > >> > Thanks,
> > >> > Chris
> > >> > _________________________________________________________________
> > >> > Share your photos with Windows Live Photos – Free.
> http://clk.atdmt.com/UKM/go/134665338/direct/01/_______________________________________________
> > >> > gdal-dev mailing list
> > >> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > > New! Receive and respond to mail from other email accounts from within
> > > Hotmail Find out how.
> > Best regards,
> > Chaitanya kumar CH.
> Add other email accounts to Hotmail in 3 easy steps. Find out how.
> <http://clk.atdmt.com/UKM/go/167688463/direct/01/>
