[gdal-dev] ogrinfo ends its work as soon as it starts
Chaitanya kumar CH
chaitanya.ch at gmail.com
Wed Oct 7 11:00:50 EDT 2009
Randy,
> Therefore, I doubt there is something wrong with my ENC file and want to use
> “ogrinfo.exe” for testing. However, the window disappear as soon as it
> appear when I dblclick it and so does some other application like
> gdalwarp.exe.
These applications are best run from command line instead of using the
icons. Run the programs from the command line using the options
described at http://gdal.org/ogr_utilities.html
Best regards,
Chaitanya kumar CH.
