[gdal-dev] Output MapInfo File with CoordSys Information
Reinaldo escada Chohfi reinaldo at geodesign.com.br
Wed Oct 7 12:33:34 EDT 2009
Hi Frank & List
I tested the program below but it does not out put the .tab or
.mif/.mid with the coordinate system.  It is always non-earth.
Could you please check it against your gdal/ogr installation to see
if something went  wrong during my compilation of gdal 1.6.2?
Thanks a lot,
Reinaldo
#include "gdal.h"
#include "ogr_spatialref.h"
#include "ogrsf_frmts.h"
#include "stdio.h"
double Lat[3], Lon[3];
int n=0; char *pszWKT = NULL;
void main()
 OGRSpatialReference oSRS;
// oSRS.SetWellKnownGeogCS( "EPSG:4326" );
 oSRS.importFromMICoordSys( "CoordSys Earth Projection 1,
104" );
 const char *pszDriverName = "MapInfo File" ;
 OGRSFDriver *poDriver;
    OGRRegisterAll();
    poDriver =
OGRSFDriverRegistrar::GetRegistrar()->GetDriverByName(
pszDriverName );
    if( poDriver == NULL )
        printf( "%s driver not
available.\n", pszDriverName );
        exit( 1 );
 OGRDataSource *poDS;
 poDS = poDriver->CreateDataSource( "c:/test01.mif",
NULL );
// poDS = poDriver->CreateDataSource( "c:/test01.tab",
NULL );
    if( poDS == NULL )
        printf( "Creation of
output file failed.\n" );
        exit( 1 );
    OGRLayer *poLayer;
    poLayer = poDS->CreateLayer( "test01",
NULL, wkbPoint, NULL );
    if( poLayer == NULL )
        printf( "Layer creation
failed.\n" );
        exit( 1 );
 OGRFieldDefn oField0( "NAME1", OFTString );
 OGRFieldDefn oField1( "NAME2", OFTString );
 oField0.SetWidth(32);
    oField1.SetWidth(32);
 if( poLayer->CreateField( &oField0 ) != OGRERR_NONE )
        printf( "Creating Name
field failed.\n" );
        exit( 1 );
 if( poLayer->CreateField( &oField1 ) != OGRERR_NONE )
field failed.\n" );
        exit( 1 );
.mif output:
Version 300
Charset "Neutral"
Delimiter ","
Columns 2
  NAME1 Char(32)
  NAME2 Char(32)
Data
Point -45.13975272 -22.69426671
    Symbol (35,0,12)
Point -45.86066928 -23.21117775
    Symbol (35,0,12)
Point -44.33023872 -22.68505859375
    Symbol (35,0,12)
.mid output:
"TEST01","TEST02"
"TEST01","TEST02"
"TEST01","TEST02"
>> Reinaldo escada Chohfi wrote:
>>> Hello List,
>>> I am still trying to get a x,y (lon/Lat) point file in
MapInfo
> format
>>> with
>>> coordinate information.
>>> I get the correct MapInfo files out (.tab or .mif) with the
x,y
> points
>>> and
>>> attributes, but without the CoordSys information.
>>> The output file is always Non-Earth.
>>> I've tried everything:
>>> oSRS.SetWellKnownGeogCS("EPSG:4326");
> 104" );
>>> Could someone PLEASE let me know what to do?
>> Reinaldo,
>> I just tried:
>> ogr2ogr -skipfailures -f "MapInfo File" out.mif
> GB4X0000.000 TUNNEL
>> and this produced a mapinfo mid/mif fileset with "CoordSys
Earth
>> Projection 1, 104" as the coord sys line. I also tested a
small
>> program:
>> #include "gdal.h"
>> int main()
> 104" );
>> and it appeared to correctly parse the Coordsys into a WGS84 srs.
>> I even tried:
>> ogr2ogr -a_srs wgs84.wkt -skipfailures -f "MapInfo
File"
> out.mif
>> data/s57/GB4X0000.000 TUNNEL
>> with wgs84.wkt holding:
GEOGCS["unnamed",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563],TOWGS84[0,0,0,-0,-0,-0,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]]
>> and things seemed to work.
>> Can you provide a more complete example that is failing for you?
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> warmerdam at pobox.com
>> light and sound - activate the windows |
http://pobox.com/~warmerdam
>> and watch the world go round - Rush | Geospatial Programmer for
Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091007/9f18740e/attachment.html
