[gdal-dev] GDAL Python bindings: coordinate transformation does
not work
Howard Butler
hobu.inc at gmail.com
Thu Oct 8 15:11:03 EDT 2009
On Oct 6, 2009, at 2:10 PM, Klaus Noekel wrote:
> Hi,
> I have just installed GDAL 1.6.1.win32-py2.6 on a Win XP system and
> set
> up the GDAL directory properly (bin directory in PATH, env variable
> points to data).
> Scripts for coordinate transformation like that below do not crash,
> but
> just seem not to do anything, i.e. the data remain unchanged instead
> of
> being reprojected. Can anybody tell me what I am doing wrong?
> The output is
> POINT( 776041.000 3386618.000)
> POINT (776041 3386618)
> where I had expected lat/long instead for point.
> Thanks a lot!
> Klaus
Klaus,
I get the following for output on my OSX box:
> POINT (-84.121611219545073 30.5802861582041)
I suspect the TransformTo is failing because the GDAL_DATA are not
being found.
Howard
