[gdal-dev] GDAL Python bindings: coordinate transformation does
not work
Howard Butler
hobu.inc at gmail.com
Thu Oct 8 15:24:27 EDT 2009
OSGeo4W should have a suitable proj.dll
Please reply to the list so others may benefit from the exchange.
Howard
On Oct 6, 2009, at 2:23 PM, Klaus Noekel wrote:
> Hi Howard,
> thanks for checking this so quickly. It still fails on my PC, and
> the env variable definitely point to the correct location.
> However, running in a DOS box I now see the error message
> ERROR 6: Unable to load PROJ.4 library (proj.dll), creation of
> OGRCoordinateTransformation failed.
> Is there another dependency that I was not aware of? Where would I
> find a matching PROJ.4 and where do I put it?
> Cheers,
> Klaus
> Howard Butler schrieb:
>> On Oct 6, 2009, at 2:10 PM, Klaus Noekel wrote:
>>> Hi,
>>> I have just installed GDAL 1.6.1.win32-py2.6 on a Win XP system
>>> and set
>>> up the GDAL directory properly (bin directory in PATH, env variable
>>> points to data).
>>> Scripts for coordinate transformation like that below do not
>>> crash, but
>>> just seem not to do anything, i.e. the data remain unchanged
>>> instead of
>>> being reprojected. Can anybody tell me what I am doing wrong?
>>> The output is
>>> POINT( 776041.000 3386618.000)
>>> POINT (776041 3386618)
>>> where I had expected lat/long instead for point.
>>> Thanks a lot!
>>> Klaus
>> Klaus,
>> I get the following for output on my OSX box:
>>> POINT (-84.121611219545073 30.5802861582041)
>> I suspect the TransformTo is failing because the GDAL_DATA are not
>> being found.
>> Howard
