[gdal-dev] Python-OGR not looping over more than 500 PGSQL
features
Chaitanya kumar CH
chaitanya.ch at gmail.com
Fri Oct 9 09:21:05 EDT 2009
Matthieu,
GetFeatureCount in postgres driver is implemented with the COUNT()
function. ( http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/pg/ogrpgtablelayer.cpp#L1895
) So it was never returning more than 500 features. IMHO, the number
500 looks like an intentional limitation, probably set on the server
connection.
On Fri, Oct 9, 2009 at 4:11 PM, Matthieu Rigal <rigal at rapideye.de> wrote:
> Hi people,
> I recently discovered a strange behaviour which was not happening before, I
> think...
> I'm using Python 2.5 with GDAL/OGR 1.6 and PGsql 8.3 on Linux.
> I am reading a table containing 858 features with several columns and
> geometry.
> I first do a SELECT on the table and the GetFeatureCount tells me 858 lines
> are being readen.
> Then I am looping on the OGR object Feature by feature, to make some
> calculation and I send an UPDATE for this particular line through another OGR
> object.
> I have a counter after every UPDATE.
> Whereas it should go through all the 858 features, it stops after having gone
> through 500 features, my counter at the end shows 500 and looking to the
> database, it clearly stops after 500.
> I've done a test on a second database and it also stopped at 500...
> Is there some recently introduced limitations on OGR side ? I have searched
> all the website without finding something about it... May it come from some
> Python memory limitation ( I doubt) ? Or from some PGSQL server limitation (I
> doubt also because 858 features are returned at the beginning ?
> Thanks for your help,
> Best Regards,
> Matthieu Rigal
> RapidEye AG
> Molkenmarkt 30
> 14776 Brandenburg an der Havel
> Germany
> Follow us on Twitter! www.twitter.com/rapideye_ag
> Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
> Management Board/Vorstand: Wolfgang G. Biedermann
> Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates:
> Juergen Breitkopf
> Commercial Register/Handelsregister Potsdam HRB 17 796
> Tax Number/Steuernummer: 048/100/00053
> VAT-Ident-Number/Ust.-ID: DE 199331235
> DIN EN ISO 9001 certified
> Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
> Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
> E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
> Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
> die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
> The information in this e-mail is intended for the named recipients
> only. It may contain privileged and confidential information. If you
> have received this communication in error, any use, copying or
> dissemination of its contents is strictly prohibited. Please erase all
> copies of the message along with any included attachments and notify
> RapidEye AG or the sender immediately by telephone at the number
> indicated on this page.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
