[Gdal-dev] Missing aaigriddataset.o on make
Alan Hale alan.hale at btclick.com
Sat Oct 10 09:51:04 EDT 2009
Sorry - just to clarify - aaigriddataset.o is missing from
/gdal-1.6.2/frmts/o/ (the path indicated in the error message) but it IS
present directly under /gdal-1.6.2/frmts/aaigrid/
Frank - to answer your question - doing make install-obj in that latter
directory gives a response "nothing to be done" - which I guess is what
you would expect!
There was previous to this error an error relating to linking :
libtool : link : unable to infer tagged configuration
libtool  link : specify a tag with '--tag'
I got past this by adding '--tag=CXX' to the line
"LIBTOOL_LINK=$(LIBTOOL) --mode=link" though I confess again that was
only a guess based on a Google search on the error.
Many thanks
Alan Hale
Chaitanya kumar CH wrote:
> Alan,
> Sorry for the previous mail. I hit the send button by accident.
> Is the file aaigriddataset.o actually missing? I guess this error
> occured during linking. Could you confirm that?
> On Sat, Oct 10, 2009 at 12:53 PM, Chaitanya kumar CH <chaitanya.ch
> <http://chaitanya.ch>@gmail.com <http://gmail.com>> wrote:
>     Alan,
>     Do you have write permissions
>     On Sat, Oct 10, 2009 at 5:52 AM, Alan Hale <alan.hale at btclick.com
>     <mailto:alan.hale at btclick.com>> wrote:
>         Hello
>         I'm attempting to install gdal-1.6.2 but when I try to "make"
>         I get the
>         error:
>         /usr/local/src/gdal-1.6.2/frmts/o/aaigriddataset.o: No such
>         file or
>         directory
>         On a guess, I tried ./configure --without-AAIGrid but this did
>         not help.
>         Any advice please? Many tahnks
>         Alan Hale
>         View this message in context:
>         http://n2.nabble.com/Missing-aaigriddataset-o-on-make-tp3798702p3798702.html
>         Sent from the GDAL - Dev mailing list archive at Nabble.com.
>         _______________________________________________
>         gdal-dev mailing list
>         gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/gdal-dev
>     Best regards,
>     Chaitanya kumar CH.
> Best regards,
> Chaitanya kumar CH.
__________ Information from ESET Smart Security, version of virus signature database 4495 (20091010) __________
The message was checked by ESET Smart Security.
http://www.eset.com
