[Gdal-dev] Missing aaigriddataset.o on make
Alan Hale alan.hale at btclick.com
Sun Oct 11 06:25:11 EDT 2009
I just tried copying aaigriddataset.o from  /frmts/aaigrid/ to /frmts/o/
and doing a "make" again. This time it is reporting not finding
/adrgdataset.o/ under /frmts/o/. I suspect this could go on and on! Is
anyone able to explain what is going wrong?
Many thanks.
Alan
Alan Hale wrote:
> Sorry - just to clarify - aaigriddataset.o is missing from
> /gdal-1.6.2/frmts/o/ (the path indicated in the error message) but it
> IS present directly under /gdal-1.6.2/frmts/aaigrid/
> Frank - to answer your question - doing make install-obj in that
> latter directory gives a response "nothing to be done" - which I guess
> is what you would expect!
> There was previous to this error an error relating to linking :
> libtool : link : unable to infer tagged configuration
> libtool  link : specify a tag with '--tag'
> I got past this by adding '--tag=CXX' to the line
> "LIBTOOL_LINK=$(LIBTOOL) --mode=link" though I confess again that was
> only a guess based on a Google search on the error.
> Many thanks
> Alan Hale
> Chaitanya kumar CH wrote:
>> Alan,
>> Sorry for the previous mail. I hit the send button by accident.
>> Is the file aaigriddataset.o actually missing? I guess this error
>> occured during linking. Could you confirm that?
>> On Sat, Oct 10, 2009 at 12:53 PM, Chaitanya kumar CH <chaitanya.ch
>> <http://chaitanya.ch>@gmail.com <http://gmail.com>> wrote:
>>     Alan,
>>     Do you have write permissions
>>     On Sat, Oct 10, 2009 at 5:52 AM, Alan Hale <alan.hale at btclick.com
>>     <mailto:alan.hale at btclick.com>> wrote:
>>         Hello
>>         I'm attempting to install gdal-1.6.2 but when I try to "make"
>>         I get the
>>         error:
>>         /usr/local/src/gdal-1.6.2/frmts/o/aaigriddataset.o: No such
>>         file or
>>         directory
>>         On a guess, I tried ./configure --without-AAIGrid but this did
>>         not help.
>>         Any advice please? Many tahnks
>>         Alan Hale
>>         View this message in context:
>> http://n2.nabble.com/Missing-aaigriddataset-o-on-make-tp3798702p3798702.html
>>         Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>         _______________________________________________
>>         gdal-dev mailing list
>>         gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>     --     Best regards,
>>     Chaitanya kumar CH.
>> Best regards,
>> Chaitanya kumar CH.
> __________ Information from ESET Smart Security, version of virus
> signature database 4495 (20091010) __________
> The message was checked by ESET Smart Security.
> http://www.eset.com
> http://www.eset.com
__________ Information from ESET Smart Security, version of virus signature database 4496 (20091010) __________
http://www.eset.com
