答复: Re: [gdal-dev] different result of ogrinfo between GDAL/OGR =?utf-8?Q?and_ FWTools?=
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Sun Oct 11 06:27:07 EDT 2009
Randy <randyqiuxy <at> hotmail.com> writes:
> Chaitanya,
> Thanks
> you, Chaitanya!
> To be
> frank, I don’t understand what you mean. Could you give me some more explicit
> guidance and where I should change the version option? I use the latest stable
Meaning was to check first if gdal versions are same by giving
ogrinfo --version
GDAL 1.7.0dev, FWTools 2.4.2, released 2009/06/24
Version cannot be changed from command line.
If gdal versions are the same then reason for different result must be somewhere
deeper.
-Jukka Rahkonen-
