[gdal-dev] Fastest vector format for combining shapefiles
Paul Meems
bontepaarden at gmail.com
Mon Oct 12 09:01:25 EDT 2009
Simon,
I agree a long way with you.
But how about a solution?
I think enough smart people are involved in OSGeo, it should be possible to
get them together and create a fully Open-Source fast vector format.
I'm not one of those but I'm willing to help with the requirements,
implementation and testing.
Along with some fund raising it could work.
Are you willing to put money where your mouth is and take the lead on this?
You can count me in.
Regards,
Paul Meems
Bontepaarden.nl
The Netherlands
Core developer of MapWindow GIS
2009/10/10 Simon Greener <simon at spatialdbadvisor.com>
> The need for a new vector file format has been discussed many times with no
> action initiated by the open source community on what to do.
> ESRI has said they will do so, but it's been several
>> years since they first announced it and when it is finally is released
>> there is no guarantee it will be under license terms open source
>> projects can use. This isn't to say it will be unusable either, we
>> just don't know.
> Ahhh, isn't it wonderful waiting for the "crumbs that will fall from the
> master's table"!
> And, "to wait" is part and parcel of being an ESRI-centric customer or
> user: strange that open source people are willing to do the same.
> (Well, at least you aren't paying for the privilege of using the stuff.)
> Why won't ESRI release an FDO (an Open Source open access API) provider for
> FGDBs rather than their own API? (I can find no reference to ESRI offering
> to do so for any of its formats.) Sounds like API lock-in is a design goal
> for the FGDB API!
> Don't forget that a FGDB is full of ESRI concepts (not OGC or SQL/MM or
> those promoted by any other standards body) - more lock-in if it becomes the
> much hoped for replacement for shapefiles. And, what's more, we know nothing
> about what will be in the API. Where is the community engagement? Will we
> end up with an API via which we cannot (four examples will suffice):
> 1. Properly design (cf CASE tool) an FGDB (cf ESRI $$ extensions to Visio);
> 2. Create an FGDB from scratch;
> 3. Write data or create important objects (ie versions);
> 4. Create FGDB spatial and attribute indexes or even use them via the API
> (cf shapefile indexing);
> These are points which have grounding in past ESRI practices. All done
> deliberately so you have to have a copy of ArcGIS to construct, design and
> get the best out of a fully specified FGDB?
> And then, when there are serious bugs, you have to wait for 18 months for a
> fix while in the Open Source community you could get one in a matter of days
> or weeks?
> Seriously, though, isn't open source about taking control of one's destiny
> and being a part of a truly open, collaborative, process and not waiting for
> the bully in the playground to tell you what you can and can't do, or who
> really isn't interested in your deadlines and real needs? Many times in my
> long GIS career I've had conversations with the 'true believers' over in
> Redlands. One was like this: "When will you support an Oracle Sdo_Geometry
> circle object in ArcSDE?". Reply: "Circles in GIS? We don't think you need
> them....".
> The fixated concentration of the GIS community on physical file formats
> feels very much like a 1960s form of data management and computing. Logical
> separation from physical implementation, normalise for edit/denormalise for
> performance, logical separation from physical implementation, normalise for
> edit/denormalise for performance, logical..... oops the record is broken
> The only reason I ever hear for physical file formats is "we need to do
> this for performance reasons"..... but this usually masks a lot of other
> reasons and assumptions (like it is "quicker and easier" that soon morphs
> into a management nightmare).....
> cynically
> Simon
> SpatialDB Advice and Design, Solutions Architecture and Programming,
> Oracle Database 10g Administrator Certified Associate; Oracle Database 10g
> SQL Certified Professional
> Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME,
> Radius Topology and Studio Specialist.
> 39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
> Website: www.spatialdbadvisor.com
> Email: simon at spatialdbadvisor.com
> Voice: +61 362 396397
> Mobile: +61 418 396391
> Skype: sggreener
> Longitude: 147.20515 (147° 12' 18" E)
> Latitude: -43.01530 (43° 00' 55" S)
> GeoHash: r22em9r98wg
> NAC:W80CK 7SWP3
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091012/a1812503/attachment-0001.html
